[postgis-tickets] r17450 - reorder wagyu line in bessie regress
Regina Obe lr at pcorp.us
Fri May 31 02:37:50 PDT 2019
Author: robe
Date: 2019-05-31 14:37:49 -0700 (Fri, 31 May 2019)
New Revision: 17450
   trunk/ci/bessie32/postgis_regress.sh
   trunk/ci/winnie/regress_postgis.sh
configure winnie to test with wagyu to better troubleshoot issue
References #4408
Modified: trunk/ci/bessie32/postgis_regress.sh
--- trunk/ci/bessie32/postgis_regress.sh	2019-05-31 20:01:11 UTC (rev 17449)
+++ trunk/ci/bessie32/postgis_regress.sh	2019-05-31 21:37:49 UTC (rev 17450)
@@ -1,6 +1,6 @@
 export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
 sh autogen.sh
-./configure --with-projdir=/usr/local --with-libiconv=/usr/local --without-interrupt-tests --with-wagyu
+./configure --with-projdir=/usr/local --with-libiconv=/usr/local --with-wagyu --without-interrupt-tests
 make clean
 make
 export PGUSER=postgres
Modified: trunk/ci/winnie/regress_postgis.sh
--- trunk/ci/winnie/regress_postgis.sh	2019-05-31 20:01:11 UTC (rev 17449)
+++ trunk/ci/winnie/regress_postgis.sh	2019-05-31 21:37:49 UTC (rev 17450)
@@ -119,6 +119,7 @@
   --with-libiconv=${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE} \
   --with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
   --with-gui --with-gettext=no \
+  --with-wagyu \
   --with-protobufdir=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE} \
   --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
   --with-pcredir=${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE} \
@@ -135,6 +136,7 @@
   --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/gdal-config \
+  --with-wagyu \
   --with-jsondir=${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE} \
