[postgis-tickets] [PostGIS] #4569: Allow SRID coercion when inserting unknown SRID geometry into known SRID column
PostGIS trac at osgeo.org
Mon Nov 4 13:10:27 PST 2019
column
 Reporter:  pramsey      |      Owner:  pramsey
     Type:  enhancement  |     Status:  new
 Priority:  medium       |  Milestone:  PostGIS 3.1.0
Component:  postgis      |    Version:  trunk
 Keywords:               |
 Currently, inserting a SRID=0 geometry into a column with SRID typmod
 results in an error, so:
 CREATE TABLE foo (g geometry(point, 4326));
 INSERT INTO foo ( 'POINT(1 1)' );
 does not work. This results in a lot of extra hand waving just to get data
 into place, and in teaching environments is annoying. The intent of
 putting unknown things into known places is fairly clear: we mean for them
 to be in the same reference system.
 This change will allow the above, but all other cases will remain the
 same: mis-matched known SRID will still generate errors.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4569>
