[postgis-tickets] [PostGIS] #4572: Bessie and Bessie32 are erroring out on upgrade compare
trac at osgeo.org
Thu Nov 7 17:44:19 PST 2019
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.0
Component: buildbots | Version: master
Keywords: |
https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32/1724/consoleFull
19:19:51 +UNEXPECTED|POSTGIS="3.1.0dev rb348507" [EXTENSION] PGSQL="110"
GEOS="3.7.2-CAPI-1.11.2 b55d2125" PROJ="6.1.0" LIBXML="2.9.9"
LIBJSON="0.13.1" LIBPROTOBUF="1.3.2" WAGYU="0.4.3 (Internal)" (core procs
from "3.1.0dev POSTGIS_REVISION" need upgrade)
Looks like PostGIS_REVISION is not being replaced.
I suspect maybe it's been an issue since the move.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4572>
