[postgis-tickets] [PostGIS] #4561: ST_AsEWKT excluding Z and M in WKT representation
trac at osgeo.org
Fri Nov 8 08:49:12 PST 2019
Reporter: tilt | Owner: pramsey
Type: defect | Status: closed
Priority: low | Milestone: PostGIS 3.0.1
Component: postgis | Version: 3.0.x
Resolution: invalid | Keywords:
Changes (by pramsey):
* status: new => closed
* resolution: => invalid
Comment:
The documentation can be updated, the ST_AsText() documentation probably
dates to pre-2.0, when ST_AsText() returned only OGC-standard (2d only)
WKT.
The function is doing exactly what it is supposed to, which is returning
the EWKT format, which is not the same as ISO format for higher
dimensions. There is no bug here.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4561#comment:1>
