[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. 7b6c600f298a26b4f6ca639ce645113192164349
git at osgeo.org
git at osgeo.org
Mon Nov 11 00:58:59 PST 2019
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
via 7b6c600f298a26b4f6ca639ce645113192164349 (commit)
from e6aa0475d5e76bd91d4da201fd609a844eaf7c62 (commit)
revisions in full, below.
commit 7b6c600f298a26b4f6ca639ce645113192164349
Author: Regina Obe <lr at pcorp.us>
Date: Mon Nov 11 00:58:58 2019 -0800
Update 'jenkins_bot.md'
formatting changes
diff --git a/jenkins_bot.md b/jenkins_bot.md
index 69e2cb4..73cb413 100644
--- a/jenkins_bot.md
+++ b/jenkins_bot.md
@@ -1,29 +1,31 @@
-### Steps to configuring a Jenkins slave bot
-Jenkins bots need Java installed
-OpenJDK 11 or higher is preferrable
-adduser jenkins
-#for password based authentication answer no
-#Make sure jenkins is in AllowUsers list of /sshd_config
-cat /etc/ssh/sshd_config | grep AllowUsers #if jenkins not listed add
-vi /etc/ssh/sshd_config #:g/AllowUsers/, :g/PermitRootLogin #change to yes so can configure - can change later to no
-service sshd restart
-#add key to list
-su jenkins
-cd ~/
-mkdir .ssh
-echo ssh-rsa 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 jenkins_slave at postgis.net >> ~/.ssh/authorized_keys
-#if issue with permissions make sure to update
-chmod 700 ~/.ssh
-chmod 600 ~/.ssh/authorized_keys
-#Once you have server ready for jenkins, from jenkins add console
-1) Add as a node
-2) In the configure it asks for path info for JDK location
-3) Specify host name and ssh port
-4) Click button to test. It should ssh in deploy slave.jar etc.
+### Steps to configuring a Jenkins slave bot
+Jenkins bots need Java installed
+OpenJDK 11 or higher is preferrable
+adduser jenkins
+#for password based authentication answer no
+#Make sure jenkins is in AllowUsers list of /sshd_config
+cat /etc/ssh/sshd_config | grep AllowUsers #if jenkins not listed add
+vi /etc/ssh/sshd_config #:g/AllowUsers/, :g/PermitRootLogin #change to yes so can configure - can change later to no
+service sshd restart
+#add key to list
+su jenkins
+cd ~/
+mkdir .ssh
+echo ssh-rsa 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 jenkins_slave at postgis.net >> ~/.ssh/authorized_keys
+#if issue with permissions make sure to update
+chmod 700 ~/.ssh
+chmod 600 ~/.ssh/authorized_keys
+#### Once you have server ready for jenkins, from jenkins add console
+1. Add as a node
+2. In the configure it asks for path info for JDK location
+3. Specify host name and ssh port
+4. Click button to test. It should ssh in deploy slave.jar etc.
Summary of changes:
jenkins_bot.md | 60 ++++++++++++++++++++++++++++++----------------------------
1 file changed, 31 insertions(+), 29 deletions(-)
hooks/post-receive
