[postgis-tickets] [PostGIS] #4573: build failure when unmodified uthash.h is installed systemwide
trac at osgeo.org
Mon Nov 11 08:32:34 PST 2019
Reporter: landry | Owner: strk
Type: patch | Status: new
Priority: high | Milestone: PostGIS 3.0.1
Component: build/upgrade/install | Version: 3.0.x
Resolution: | Keywords:
Comment (by Algunenano):
I don't see anything wrong with the change, but there wouldn't be any
issue if you weren't including a PATH inside the CFLAGS and used CPPFLAGS
for this instead, right? Are you adding `-I/usr/local/include` to the
CFLAGS in your call to configure or is something broken in our side?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4573#comment:4>
