[postgis-tickets] [SCM] PostGIS branch master updated. 7613d9ae7af8144043dad3e42131a881142e17f0
Sun Nov 17 11:03:02 PST 2019
the project "PostGIS".
       via  7613d9ae7af8144043dad3e42131a881142e17f0 (commit)
      from  8625813329c8c6be963bdca48657629c45f68c26 (commit)
revisions in full, below.
commit 7613d9ae7af8144043dad3e42131a881142e17f0
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Nov 17 14:02:54 2019 -0500
    postgis_raster installed from unpackaged needs to specify schema of postgis. References #4581 for master PostGIS 3.1
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index e3c93a1..b29db3b 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2804,6 +2804,7 @@ AS $$
 $$ LANGUAGE 'sql' STABLE;
 -- Availability: 2.5.0
+-- Changed: 3.0.1 install from unpackaged should include postgis schema #4581
 -- Changed: 3.0.0 also upgrade postgis_raster if it exists
 CREATE OR REPLACE FUNCTION postgis_extensions_upgrade() RETURNS text
 AS $$
@@ -2850,7 +2851,7 @@ BEGIN
 				 -- TODO: How do we tell if PostGIS Tiger Geocoder is available  ?
 			THEN
-				sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged';
+				sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged SCHEMA @extschema@';
 				RAISE NOTICE 'Packaging extension %', rec.name;
 				RAISE DEBUG '%', sql;
 				EXECUTE sql;
Summary of changes:
 postgis/postgis.sql.in | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
hooks/post-receive
