[postgis-tickets] [PostGIS] #4585: st_astwkb not returning valid geometry
trac at osgeo.org
Tue Nov 19 06:21:10 PST 2019
Reporter: furstenheim | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.9
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by nicklas):
Hi
What you posted is not a valid geojson. Both because of the question mark
in it and because of the lack of nestling.
It is just a lot of point couple arrays not a point array in a ring array
as polygon demands.
So, what I guess that you want to write is:
select
st_isvalidreason(
st_geomfromtwkb(
st_astwkb(
st_geomfromgeojson(
"type": "Polygon", "coordinates": [2.1776390993201,41.3722988965004],
[2.17763909886103,41.37229889631543],[2.17763909900003,41.3722988970001],
[2.1820804568871637,41.37027921005133],[2.18208045654673,41.3702792096251],
[2.1776390993201,41.3722988965004?]
Then I get the error Too few points for geometry type.
That is because the points are so close so many of them gets removed as
duplicates when creating twkb.
twkb by default only saves the integer part for geometry.
But even if you tell it to store 7 decimals it is only 2 different points,
not 3 as needed for a polygon to be valid.
If you manually remove the precesion beyond 7 decimals in your data you
see that you get the same result from geojson:
select st_isvalidreason(
st_geomfromgeojson('{
"type": "Polygon", "coordinates": [[
[2.1776390,41.3722988],
[2.1820804,41.3702792],
[2.1776390,41.3722988]]]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4585#comment:1>
