[postgis-tickets] [SCM] PostGIS branch master updated. 5887c919048bd2af01542f4dc53da3693e59197a
Fri Nov 22 06:10:46 PST 2019
the project "PostGIS".
       via  5887c919048bd2af01542f4dc53da3693e59197a (commit)
      from  60bb1915f187d47c219eeac4f0f7edb7cc7cf4b2 (commit)
revisions in full, below.
commit 5887c919048bd2af01542f4dc53da3693e59197a
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri Nov 22 11:42:41 2019 +0100
    Avoid throwing during update if st_union(geometry) doesn't exist
    Closes https://github.com/postgis/postgis/pull/517
    References #4588
diff --git a/NEWS b/NEWS
index aa23b3d..e18dfb0 100644
--- a/NEWS
+++ b/NEWS
@@ -19,6 +19,7 @@ PostGIS 3.1.0
            ST_SnapToGrid optimized. (Darafei Praliaskouski)
   - #4574, Link Time Optimizations enabled (Darafei Praliaskouski)
   - #4578, Add parallellism and cost properties to brin functions (Raúl Marín)
+  - #4473, Silence yacc warnings (Raúl Marín)
 * Bug fixes *
   - #4544, Fix leak when parsing a WKT geometry_list (Raúl Marín)
@@ -26,7 +27,7 @@ PostGIS 3.1.0
   - #4549, Fix several functions when the schema isn't the search_path (Raúl Marín)
   - #4546, Fix PLPGSQL functions missing the schema qualification (Raúl Marín)
   - #4558, Fix oversimplification of polygon inner rings (Raúl Marín)
-  - #4473, Silence yacc warnings (Raúl Marín)
+  - #4588, Fix update when st_union(geometry) doesn't exist (Raúl Marín)
 PostGIS 3.0.0
diff --git a/postgis/postgis_after_upgrade.sql b/postgis/postgis_after_upgrade.sql
index 2c0fb94..9bbd5cc 100644
--- a/postgis/postgis_after_upgrade.sql
+++ b/postgis/postgis_after_upgrade.sql
@@ -243,8 +243,12 @@ $$
 BEGIN
 IF _postgis_scripts_pgsql_version()::integer >= 96 THEN
 -- mark ST_Union agg as parallel safe if it is not already
-	UPDATE pg_proc SET proparallel = 's'
-	WHERE oid = 'st_union(geometry)'::regprocedure AND proparallel = 'u';
+        BEGIN
+            UPDATE pg_proc SET proparallel = 's'
+            WHERE oid = 'st_union(geometry)'::regprocedure AND proparallel = 'u';
+        EXCEPTION WHEN OTHERS THEN
+            RAISE DEBUG 'Could not update st_union(geometry): %', SQLERRM;
+        END;
 END IF;
 END;
Summary of changes:
 NEWS                              | 3 ++-
 postgis/postgis_after_upgrade.sql | 8 ++++++--
 2 files changed, 8 insertions(+), 3 deletions(-)
hooks/post-receive
