[postgis-tickets] [SCM] PostGIS branch stable-2.4 updated. b1732eb6f704749dbae8bb351ae62c2f14d865dd
Fri Nov 22 06:15:35 PST 2019
the project "PostGIS".
The branch, stable-2.4 has been updated
       via  b1732eb6f704749dbae8bb351ae62c2f14d865dd (commit)
      from  48373292aa8f8c0519559f1f144621c6d61e6719 (commit)
revisions in full, below.
commit b1732eb6f704749dbae8bb351ae62c2f14d865dd
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri Nov 22 11:42:41 2019 +0100
    Avoid throwing during update if st_union(geometry) doesn't exist
    References #4588
diff --git a/NEWS b/NEWS
index 90be976..ee53a2a 100644
--- a/NEWS
+++ b/NEWS
@@ -20,6 +20,7 @@ XXXX/XX/XX
   - #4547, Fix AddRasterConstraints handling of empty tables (Sandro Santilli)
   - #4549, Fix schema qualification of internal types (Raúl Marín)
   - #4546, Fix PLPGSQL functions missing the schema qualification (Raúl Marín)
+  - #4588, Fix update when st_union(geometry) doesn't exist (Raúl Marín)
 PostGIS 2.4.8
diff --git a/postgis/postgis_drop_after.sql b/postgis/postgis_drop_after.sql
index c8ae340..f47c32c 100644
--- a/postgis/postgis_drop_after.sql
+++ b/postgis/postgis_drop_after.sql
@@ -178,8 +178,12 @@ $$
 BEGIN
 IF _postgis_scripts_pgsql_version()::integer >= 96 THEN
 -- mark ST_Union agg as parallel safe if it is not already
-	UPDATE pg_proc SET proparallel = 's'
-	WHERE oid = 'st_union(geometry)'::regprocedure AND proparallel = 'u';
+        BEGIN
+            UPDATE pg_proc SET proparallel = 's'
+            WHERE oid = 'st_union(geometry)'::regprocedure AND proparallel = 'u';
+        EXCEPTION WHEN OTHERS THEN
+            RAISE DEBUG 'Could not update st_union(geometry): %', SQLERRM;
+        END;
 END IF;
 END;
Summary of changes:
 NEWS                           | 1 +
 postgis/postgis_drop_after.sql | 8 ++++++--
 2 files changed, 7 insertions(+), 2 deletions(-)
hooks/post-receive
