[postgis-tickets] [SCM] PostGIS branch master updated. d6ac9a570dddbb51b804b49435a0a132670f689b
Sat Nov 23 06:18:36 PST 2019
the project "PostGIS".
       via  d6ac9a570dddbb51b804b49435a0a132670f689b (commit)
      from  2839c9415a6ffa9ca4cd850e2119f1b9b877fef0 (commit)
revisions in full, below.
commit d6ac9a570dddbb51b804b49435a0a132670f689b
Author: Raúl Marín <git at rmr.ninja>
Date:   Sat Nov 23 15:18:23 2019 +0100
    liblwgeom.h: Fix some documentation issues
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index 3e01ee1..516cfaa 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -1034,7 +1034,7 @@ extern POINTARRAY *ptarray_addPoint(const POINTARRAY *pa, uint8_t *p, size_t pdi
  * @brief Remove a point from a pointarray.
- *  @param which -  is the offset (starting at 0)
+ * @param where -  is the offset (starting at 0)
  * @return #POINTARRAY is newly allocated
 extern POINTARRAY *ptarray_removePoint(POINTARRAY *pa, uint32_t where);
@@ -2141,22 +2141,25 @@ LWGEOM_UNPARSER_RESULT;
-* @param lwgeom geometry to convert to WKT
+* @param geom geometry to convert to WKT
 * @param variant output format to use (WKT_ISO, WKT_SFSQL, WKT_EXTENDED)
+* @param size_out (Out parameter) size of the buffer
 extern char*   lwgeom_to_wkt(const LWGEOM *geom, uint8_t variant, int precision, size_t *size_out);
 *                (WKB_ISO, WKB_SFSQL, WKB_EXTENDED, WKB_NDR, WKB_XDR)
 extern uint8_t*  lwgeom_to_wkb(const LWGEOM *geom, uint8_t variant, size_t *size_out);
-* @param lwgeom geometry to convert to HEXWKB
+* @param geom geometry to convert to HEXWKB
 extern char*   lwgeom_to_hexwkb(const LWGEOM *geom, uint8_t variant, size_t *size_out);
@@ -2166,9 +2169,9 @@ extern char*   lwgeom_to_hexwkb(const LWGEOM *geom, uint8_t variant, size_t *siz
 extern char *lwgeom_to_ewkt(const LWGEOM *lwgeom);
- * @param check parser check flags, see LW_PARSER_CHECK_* macros
- * @param size length of WKB byte buffer
+ * @param wkb_size length of WKB byte buffer
  * @param wkb WKB byte buffer
+ * @param check parser check flags, see LW_PARSER_CHECK_* macros
 extern LWGEOM* lwgeom_from_wkb(const uint8_t *wkb, const size_t wkb_size, const char check);
@@ -2208,8 +2211,9 @@ extern char *lwmessage_truncate(char *str, int startpos, int endpos, int maxleng
+ * @param twkb Input twkb buffer
+ * @param twkb_size parser check flags, see LW_PARSER_CHECK_* macros
- * @param size parser check flags, see LW_PARSER_CHECK_* macros
 extern LWGEOM* lwgeom_from_twkb(const uint8_t *twkb, size_t twkb_size, char check);
@@ -2304,7 +2308,7 @@ typedef enum {
  * @param geom input geometry
  * @param tol tolerance, semantic driven by tolerance_type
- * @param tolerance_type see LW_LINEARIZE_TOLERANCE_TYPE
+ * @param type see LW_LINEARIZE_TOLERANCE_TYPE
  * @param flags bitwise OR of operational flags, see LW_LINEARIZE_FLAGS
  * @return a newly allocated LWGEOM
@@ -2391,7 +2395,7 @@ projPJ projpj_from_string(const char* txt);
  * Transform (reproject) a geometry in-place.
  * @param geom the geometry to transform
- * @param PJ the input and output
+ * @param pj the input and output
 int lwgeom_transform(LWGEOM *geom, LWPROJ* pj);
 int ptarray_transform(POINTARRAY *pa, LWPROJ* pj);
Summary of changes:
 liblwgeom/liblwgeom.h.in | 22 +++++++++++++---------
 1 file changed, 13 insertions(+), 9 deletions(-)
hooks/post-receive
