[postgis-tickets] [PostGIS] #4590: Upgrading PostGIS 3.0 PG 11 to PostGIS 3.0 PG 12 errors after pg_upgrade - st_linecrossingdirection
trac at osgeo.org
Mon Nov 25 03:34:26 PST 2019
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.1
Component: build/upgrade/install | Version: 3.0.x
Resolution: | Keywords:
Comment (by Algunenano):
Let's fix this before 3.0.1: https://github.com/postgis/postgis/pull/519
The exceptions in `postgis_before_upgrade.sql` should be enough the handle
the change
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4590#comment:3>
