[postgis-tickets] [SCM] PostGIS branch master updated. 1ceef381a78b1724281f2c63af64e796a06a7b50
git at osgeo.org
git at osgeo.org
Mon Nov 25 04:45:17 PST 2019
the project "PostGIS".
via 1ceef381a78b1724281f2c63af64e796a06a7b50 (commit)
from d6ac9a570dddbb51b804b49435a0a132670f689b (commit)
revisions in full, below.
commit 1ceef381a78b1724281f2c63af64e796a06a7b50
Author: Raúl Marín <git at rmr.ninja>
Date: Mon Nov 25 12:33:23 2019 +0100
Fix pg_upgrade issue with st_linecrossingdirection
References #4590
Closes https://github.com/CartoDB/Windshaft-cartodb/pull/1143
diff --git a/NEWS b/NEWS
index e18dfb0..20ef5c1 100644
--- a/NEWS
+++ b/NEWS
@@ -28,6 +28,7 @@ PostGIS 3.1.0
- #4546, Fix PLPGSQL functions missing the schema qualification (Raúl Marín)
- #4558, Fix oversimplification of polygon inner rings (Raúl Marín)
- #4588, Fix update when st_union(geometry) doesn't exist (Raúl Marín)
+ - #4590, Fix pg_upgrade issue with st_linecrossingdirection (Raúl Marín)
PostGIS 3.0.0
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index c154fe9..9ad89be 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4123,7 +4123,7 @@ CREATE OR REPLACE FUNCTION postgis_index_supportfn (internal)
-- Availability: 1.4.0
-CREATE OR REPLACE FUNCTION ST_LineCrossingDirection(geom1 geometry, geom2 geometry)
+CREATE OR REPLACE FUNCTION ST_LineCrossingDirection(line1 geometry, line2 geometry)
RETURNS integer
AS 'MODULE_PATHNAME', 'ST_LineCrossingDirection'
SUPPORT postgis_index_supportfn
Summary of changes:
NEWS | 1 +
postgis/postgis.sql.in | 2 +-
2 files changed, 2 insertions(+), 1 deletion(-)
hooks/post-receive
