[postgis-tickets] r17879 - Try and be a little broader in dropping temporary old signature
Paul Ramsey pramsey at cleverelephant.ca
Mon Oct 7 10:32:14 PDT 2019
Author: pramsey
Date: 2019-10-07 10:32:14 -0700 (Mon, 07 Oct 2019)
New Revision: 17879
   trunk/postgis/postgis_before_upgrade.sql
References #4521
Modified: trunk/postgis/postgis_before_upgrade.sql
--- trunk/postgis/postgis_before_upgrade.sql	2019-10-07 11:41:55 UTC (rev 17878)
+++ trunk/postgis/postgis_before_upgrade.sql	2019-10-07 17:32:14 UTC (rev 17879)
@@ -168,7 +168,7 @@
 SELECT _postgis_drop_function_if_needed
 	'ST_AsGeoJson',
-	$args$r record, geom_column text DEFAULT ''::text, maxdecimaldigits integer DEFAULT 15, pretty_print boolean DEFAULT false$args$
+	'r record, geom_column text, maxdecimaldigits integer, pretty_print boolean'
 -- FUNCTION _st_orderingequals changed argument names in 3.0
