[postgis-tickets] r17885 - Change to package 3.8.0rc2 for windows, prepare for 3.0.0rc1 release
Regina Obe
lr at pcorp.us
Mon Oct 7 11:11:49 PDT 2019
Author: robe
Date: 2019-10-07 23:11:49 -0700 (Mon, 07 Oct 2019)
New Revision: 17885
trunk/ChangeLog
trunk/ci/winnie/package_postgis.sh
Modified: trunk/ChangeLog
--- trunk/ChangeLog 2019-10-08 00:48:44 UTC (rev 17884)
+++ trunk/ChangeLog 2019-10-08 06:11:49 UTC (rev 17885)
@@ -1,3 +1,339 @@
+2019-10-07 11:41 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17878] configure.ac: Fix lib detection with "--with-jsondir"
+ flag
+ Patch by jabakobob
+ References #4528
+2019-10-07 10:38 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17877] configure.ac: Fix --with-jsondir ldflags
+ Fixes #4528
+2019-10-07 10:29 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17876] postgis/lwgeom_functions_basic.c, postgis/lwgeom_geos.c,
+ postgis/lwgeom_sfcgal.c: Address compiler warnings
+ Closes #4527
+ Closes https://github.com/postgis/postgis/pull/490
+2019-10-07 07:00 Sandro Santilli <strk at kbt.io>
+ * [r17875] raster/rt_pg/rtpg_mapalgebra.c: Use clang pragma only
+ with clang
+ Hopefully fixes #4526
+2019-10-07 06:57 Regina Obe <lr at pcorp.us>
+ * [r17874] doc/po/ja/extras_topology.xml.po,
+ doc/po/ja/reference.xml.po, doc/po/ko_KR/extras_topology.xml.po,
+ doc/po/ko_KR/reference.xml.po,
+ doc/po/pt_BR/extras_topology.xml.po,
+ doc/po/pt_BR/reference.xml.po: Fix tag issues
+2019-10-07 06:40 Sandro Santilli <strk at kbt.io>
+ * [r17873] .editorconfig, utils/postgis_proc_upgrade.pl: Tweak
+ editorconfig for postgis_proc_upgrade.pl and indent it properly
+ It looks like most lines are using 4-spaces indent, make that
+ official
+ and tweak the non-conforming lines (53 lines over 580 total
+ lines)
+2019-10-07 06:18 Regina Obe <lr at pcorp.us>
+ * [r17872] doc/po/de/reference.xml.po: remove reference_exception
+ evidentally was taken out of list
+2019-10-07 05:07 Regina Obe <lr at pcorp.us>
+ * [r17871] doc/Makefile.in: Add reference_exception.xml -- is
+ referenced in reference.xml
+ Missing file causing translation to fail
+ references #4525 for PostGIS 3.0.
+2019-10-07 04:44 Regina Obe <lr at pcorp.us>
+ * [r17870] doc/po/ja/extras.xml.po,
+ doc/po/ja/extras_address_standardizer.xml.po,
+ doc/po/ja/extras_historytable.xml.po,
+ doc/po/ja/extras_tigergeocoder.xml.po,
+ doc/po/ja/extras_topology.xml.po, doc/po/ja/faq.xml.po,
+ doc/po/ja/faq_raster.xml.po, doc/po/ja/installation.xml.po,
+ doc/po/ja/introduction.xml.po, doc/po/ja/performance_tips.xml.po,
+ doc/po/ja/postgis.xml.po, doc/po/ja/reference.xml.po,
+ doc/po/ja/reference_accessor.xml.po,
+ doc/po/ja/reference_bbox.xml.po,
+ doc/po/ja/reference_cluster.xml.po,
+ doc/po/ja/reference_constructor.xml.po,
+ doc/po/ja/reference_editor.xml.po,
+ doc/po/ja/reference_guc.xml.po, doc/po/ja/reference_input.xml.po,
+ doc/po/ja/reference_lrs.xml.po,
+ doc/po/ja/reference_management.xml.po,
+ doc/po/ja/reference_measure.xml.po,
+ doc/po/ja/reference_operator.xml.po,
+ doc/po/ja/reference_output.xml.po,
+ doc/po/ja/reference_processing.xml.po,
+ doc/po/ja/reference_raster.xml.po,
+ doc/po/ja/reference_relationship.xml.po,
+ doc/po/ja/reference_sfcgal.xml.po,
+ doc/po/ja/reference_srs.xml.po,
+ doc/po/ja/reference_trajectory.xml.po,
+ doc/po/ja/reference_transaction.xml.po,
+ doc/po/ja/reference_transformation.xml.po,
+ doc/po/ja/reference_troubleshooting.xml.po,
+ doc/po/ja/reference_type.xml.po,
+ doc/po/ja/reference_validation.xml.po,
+ doc/po/ja/reference_version.xml.po,
+ doc/po/ja/release_notes.xml.po, doc/po/ja/reporting.xml.po,
+ doc/po/ja/using_postgis_app.xml.po,
+ doc/po/ja/using_postgis_dataman.xml.po,
+ doc/po/ja/using_raster_dataman.xml.po,
+ doc/po/ko_KR/extras.xml.po,
+ doc/po/ko_KR/extras_address_standardizer.xml.po,
+ doc/po/ko_KR/extras_historytable.xml.po,
+ doc/po/ko_KR/extras_tigergeocoder.xml.po,
+ doc/po/ko_KR/extras_topology.xml.po, doc/po/ko_KR/faq.xml.po,
+ doc/po/ko_KR/faq_raster.xml.po, doc/po/ko_KR/installation.xml.po,
+ doc/po/ko_KR/introduction.xml.po,
+ doc/po/ko_KR/performance_tips.xml.po,
+ doc/po/ko_KR/postgis.xml.po, doc/po/ko_KR/reference.xml.po,
+ doc/po/ko_KR/reference_accessor.xml.po,
+ doc/po/ko_KR/reference_bbox.xml.po,
+ doc/po/ko_KR/reference_cluster.xml.po,
+ doc/po/ko_KR/reference_constructor.xml.po,
+ doc/po/ko_KR/reference_editor.xml.po,
+ doc/po/ko_KR/reference_guc.xml.po,
+ doc/po/ko_KR/reference_input.xml.po,
+ doc/po/ko_KR/reference_lrs.xml.po,
+ doc/po/ko_KR/reference_management.xml.po,
+ doc/po/ko_KR/reference_measure.xml.po,
+ doc/po/ko_KR/reference_operator.xml.po,
+ doc/po/ko_KR/reference_output.xml.po,
+ doc/po/ko_KR/reference_processing.xml.po,
+ doc/po/ko_KR/reference_raster.xml.po,
+ doc/po/ko_KR/reference_relationship.xml.po,
+ doc/po/ko_KR/reference_sfcgal.xml.po,
+ doc/po/ko_KR/reference_srs.xml.po,
+ doc/po/ko_KR/reference_trajectory.xml.po,
+ doc/po/ko_KR/reference_transaction.xml.po,
+ doc/po/ko_KR/reference_transformation.xml.po,
+ doc/po/ko_KR/reference_troubleshooting.xml.po,
+ doc/po/ko_KR/reference_type.xml.po,
+ doc/po/ko_KR/reference_validation.xml.po,
+ doc/po/ko_KR/reference_version.xml.po,
+ doc/po/ko_KR/release_notes.xml.po, doc/po/ko_KR/reporting.xml.po,
+ doc/po/ko_KR/using_postgis_app.xml.po,
+ doc/po/ko_KR/using_postgis_dataman.xml.po,
+ doc/po/ko_KR/using_raster_dataman.xml.po,
+ doc/po/pt_BR/extras.xml.po,
+ doc/po/pt_BR/extras_address_standardizer.xml.po,
+ doc/po/pt_BR/extras_historytable.xml.po,
+ doc/po/pt_BR/extras_tigergeocoder.xml.po,
+ doc/po/pt_BR/extras_topology.xml.po, doc/po/pt_BR/faq.xml.po,
+ doc/po/pt_BR/faq_raster.xml.po, doc/po/pt_BR/installation.xml.po,
+ doc/po/pt_BR/introduction.xml.po,
+ doc/po/pt_BR/performance_tips.xml.po,
+ doc/po/pt_BR/postgis.xml.po, doc/po/pt_BR/reference.xml.po,
+ doc/po/pt_BR/reference_accessor.xml.po,
+ doc/po/pt_BR/reference_bbox.xml.po,
+ doc/po/pt_BR/reference_cluster.xml.po,
+ doc/po/pt_BR/reference_constructor.xml.po,
+ doc/po/pt_BR/reference_editor.xml.po,
+ doc/po/pt_BR/reference_guc.xml.po,
+ doc/po/pt_BR/reference_input.xml.po,
+ doc/po/pt_BR/reference_lrs.xml.po,
+ doc/po/pt_BR/reference_management.xml.po,
+ doc/po/pt_BR/reference_measure.xml.po,
+ doc/po/pt_BR/reference_operator.xml.po,
+ doc/po/pt_BR/reference_output.xml.po,
+ doc/po/pt_BR/reference_processing.xml.po,
+ doc/po/pt_BR/reference_raster.xml.po,
+ doc/po/pt_BR/reference_relationship.xml.po,
+ doc/po/pt_BR/reference_sfcgal.xml.po,
+ doc/po/pt_BR/reference_srs.xml.po,
+ doc/po/pt_BR/reference_trajectory.xml.po,
+ doc/po/pt_BR/reference_transaction.xml.po,
+ doc/po/pt_BR/reference_transformation.xml.po,
+ doc/po/pt_BR/reference_troubleshooting.xml.po,
+ doc/po/pt_BR/reference_type.xml.po,
+ doc/po/pt_BR/reference_validation.xml.po,
+ doc/po/pt_BR/reference_version.xml.po,
+ doc/po/pt_BR/release_notes.xml.po, doc/po/pt_BR/reporting.xml.po,
+ doc/po/pt_BR/using_postgis_app.xml.po,
+ doc/po/pt_BR/using_postgis_dataman.xml.po,
+ doc/po/pt_BR/using_raster_dataman.xml.po: Update more po files
+2019-10-07 03:02 Regina Obe <lr at pcorp.us>
+ * [r17869] doc/po/it_IT/extras.xml.po,
+ doc/po/it_IT/extras_address_standardizer.xml.po,
+ doc/po/it_IT/extras_historytable.xml.po,
+ doc/po/it_IT/extras_tigergeocoder.xml.po,
+ doc/po/it_IT/extras_topology.xml.po, doc/po/it_IT/faq.xml.po,
+ doc/po/it_IT/faq_raster.xml.po, doc/po/it_IT/installation.xml.po,
+ doc/po/it_IT/introduction.xml.po,
+ doc/po/it_IT/performance_tips.xml.po,
+ doc/po/it_IT/postgis.xml.po, doc/po/it_IT/reference.xml.po,
+ doc/po/it_IT/reference_accessor.xml.po,
+ doc/po/it_IT/reference_bbox.xml.po,
+ doc/po/it_IT/reference_cluster.xml.po,
+ doc/po/it_IT/reference_constructor.xml.po,
+ doc/po/it_IT/reference_editor.xml.po,
+ doc/po/it_IT/reference_guc.xml.po,
+ doc/po/it_IT/reference_input.xml.po,
+ doc/po/it_IT/reference_lrs.xml.po,
+ doc/po/it_IT/reference_management.xml.po,
+ doc/po/it_IT/reference_measure.xml.po,
+ doc/po/it_IT/reference_operator.xml.po,
+ doc/po/it_IT/reference_output.xml.po,
+ doc/po/it_IT/reference_processing.xml.po,
+ doc/po/it_IT/reference_raster.xml.po,
+ doc/po/it_IT/reference_relationship.xml.po,
+ doc/po/it_IT/reference_sfcgal.xml.po,
+ doc/po/it_IT/reference_srs.xml.po,
+ doc/po/it_IT/reference_trajectory.xml.po,
+ doc/po/it_IT/reference_transaction.xml.po,
+ doc/po/it_IT/reference_transformation.xml.po,
+ doc/po/it_IT/reference_troubleshooting.xml.po,
+ doc/po/it_IT/reference_type.xml.po,
+ doc/po/it_IT/reference_validation.xml.po,
+ doc/po/it_IT/reference_version.xml.po,
+ doc/po/it_IT/release_notes.xml.po, doc/po/it_IT/reporting.xml.po,
+ doc/po/it_IT/using_postgis_app.xml.po,
+ doc/po/it_IT/using_postgis_dataman.xml.po,
+ doc/po/it_IT/using_raster_dataman.xml.po: update IT from
+ transifex
+2019-10-07 02:58 Regina Obe <lr at pcorp.us>
+ * [r17868] doc/po/de/extras.xml.po,
+ doc/po/de/extras_address_standardizer.xml.po,
+ doc/po/de/extras_historytable.xml.po,
+ doc/po/de/extras_tigergeocoder.xml.po,
+ doc/po/de/extras_topology.xml.po, doc/po/de/faq.xml.po,
+ doc/po/de/faq_raster.xml.po, doc/po/de/installation.xml.po,
+ doc/po/de/introduction.xml.po, doc/po/de/performance_tips.xml.po,
+ doc/po/de/postgis.xml.po, doc/po/de/reference.xml.po,
+ doc/po/de/reference_accessor.xml.po,
+ doc/po/de/reference_bbox.xml.po,
+ doc/po/de/reference_cluster.xml.po,
+ doc/po/de/reference_constructor.xml.po,
+ doc/po/de/reference_editor.xml.po,
+ doc/po/de/reference_guc.xml.po, doc/po/de/reference_input.xml.po,
+ doc/po/de/reference_lrs.xml.po,
+ doc/po/de/reference_management.xml.po,
+ doc/po/de/reference_measure.xml.po,
+ doc/po/de/reference_operator.xml.po,
+ doc/po/de/reference_output.xml.po,
+ doc/po/de/reference_processing.xml.po,
+ doc/po/de/reference_raster.xml.po,
+ doc/po/de/reference_relationship.xml.po,
+ doc/po/de/reference_sfcgal.xml.po,
+ doc/po/de/reference_srs.xml.po,
+ doc/po/de/reference_trajectory.xml.po,
+ doc/po/de/reference_transaction.xml.po,
+ doc/po/de/reference_transformation.xml.po,
+ doc/po/de/reference_troubleshooting.xml.po,
+ doc/po/de/reference_type.xml.po,
+ doc/po/de/reference_validation.xml.po,
+ doc/po/de/reference_version.xml.po,
+ doc/po/de/release_notes.xml.po, doc/po/de/reporting.xml.po,
+ doc/po/de/using_postgis_app.xml.po,
+ doc/po/de/using_postgis_dataman.xml.po,
+ doc/po/de/using_raster_dataman.xml.po: uodate de files from
+ transifex
+2019-10-07 01:38 Regina Obe <lr at pcorp.us>
+ * [r17867] doc/reference.xml: take out reference_misc entirely
+ instead of just commenting it out. Think it might be causing
+ issues with transifex
+2019-10-07 01:36 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17865] postgis/lwgeom_functions_basic.c, postgis/lwgeom_geos.c,
+ raster/rt_pg/rtpg_mapalgebra.c: Guard some newer GCC'isms to
+ allow older platforms
+ to still build
+2019-10-07 01:31 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17864] utils/postgis_proc_upgrade.pl: Use older perl idiom to
+ allow build on
+ older platforms still
+2019-10-07 01:29 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17863] postgis/lwgeom_accum.c: datumCopy has to happen in agg
+ context or else
+ objects larger than datum size will be lost.
+ Shows up in 32 bit because float8 doesn't fit
+ on a datum.
+ Closes #4522
+2019-10-07 00:46 Regina Obe <lr at pcorp.us>
+ * [r17861] doc/.tx/config: Get rid of reference_temporal. that
+ evidentally was removed
+2019-10-07 00:16 Regina Obe <lr at pcorp.us>
+ * [r17860] doc/po/templates/extras.xml.pot,
+ doc/po/templates/extras_address_standardizer.xml.pot,
+ doc/po/templates/extras_historytable.xml.pot,
+ doc/po/templates/extras_tigergeocoder.xml.pot,
+ doc/po/templates/extras_topology.xml.pot,
+ doc/po/templates/faq.xml.pot,
+ doc/po/templates/faq_raster.xml.pot,
+ doc/po/templates/installation.xml.pot,
+ doc/po/templates/introduction.xml.pot,
+ doc/po/templates/performance_tips.xml.pot,
+ doc/po/templates/postgis.xml.pot,
+ doc/po/templates/reference.xml.pot,
+ doc/po/templates/reference_accessor.xml.pot,
+ doc/po/templates/reference_bbox.xml.pot,
+ doc/po/templates/reference_cluster.xml.pot,
+ doc/po/templates/reference_constructor.xml.pot,
+ doc/po/templates/reference_editor.xml.pot,
+ doc/po/templates/reference_guc.xml.pot,
+ doc/po/templates/reference_input.xml.pot,
+ doc/po/templates/reference_lrs.xml.pot,
+ doc/po/templates/reference_management.xml.pot,
+ doc/po/templates/reference_measure.xml.pot,
+ doc/po/templates/reference_operator.xml.pot,
+ doc/po/templates/reference_output.xml.pot,
+ doc/po/templates/reference_processing.xml.pot,
+ doc/po/templates/reference_raster.xml.pot,
+ doc/po/templates/reference_relationship.xml.pot,
+ doc/po/templates/reference_sfcgal.xml.pot,
+ doc/po/templates/reference_srs.xml.pot,
+ doc/po/templates/reference_temporal.xml.pot,
+ doc/po/templates/reference_trajectory.xml.pot,
+ doc/po/templates/reference_transaction.xml.pot,
+ doc/po/templates/reference_transformation.xml.pot,
+ doc/po/templates/reference_troubleshooting.xml.pot,
+ doc/po/templates/reference_type.xml.pot,
+ doc/po/templates/reference_validation.xml.pot,
+ doc/po/templates/reference_version.xml.pot,
+ doc/po/templates/release_notes.xml.pot,
+ doc/po/templates/reporting.xml.pot,
+ doc/po/templates/using_postgis_app.xml.pot,
+ doc/po/templates/using_postgis_dataman.xml.pot,
+ doc/po/templates/using_raster_dataman.xml.pot: Update pot files
+ -- references #4525
+2019-10-06 15:44 Regina Obe <lr at pcorp.us>
+ * [r17858] ChangeLog, NEWS, README.postgis, doc/release_notes.xml:
+ Change expected release from 10/5 to 10/8
2019-10-05 18:06 Regina Obe <lr at pcorp.us>
* [r17857] ChangeLog, NEWS, README.postgis, Version.config,
Modified: trunk/ci/winnie/package_postgis.sh
--- trunk/ci/winnie/package_postgis.sh 2019-10-08 00:48:44 UTC (rev 17884)
+++ trunk/ci/winnie/package_postgis.sh 2019-10-08 06:11:49 UTC (rev 17885)
@@ -16,7 +16,7 @@
#otherwise use the ones jenkins passes thru
#!/bin/bash
if [[ "${OVERRIDE}" == '' ]] ; then
- export GEOS_VER=3.8.0beta1
+ export GEOS_VER=3.8.0rc2
export GDAL_VER=2.2.4
export PROJ_VER=4.9.3
export SFCGAL_VER=1.3.2
