[postgis-tickets] r17891 - Remove HAVE_LIBJSON_C
Raul raul at rmr.ninja
Tue Oct 8 04:48:33 PDT 2019
Author: algunenano
Date: 2019-10-08 04:48:33 -0700 (Tue, 08 Oct 2019)
New Revision: 17891
   trunk/configure.ac
   trunk/liblwgeom/lwin_geojson.c
   trunk/postgis/lwgeom_in_geojson.c
   trunk/postgis_config.h.in
Patch by jabakobob
References #4528
Modified: trunk/configure.ac
--- trunk/configure.ac	2019-10-08 11:40:36 UTC (rev 17890)
+++ trunk/configure.ac	2019-10-08 11:48:33 UTC (rev 17891)
@@ -910,7 +910,6 @@
 CHECK_JSON=yes
 HAVE_JSON=no
-HAVE_JSON_C=no
 AC_ARG_WITH([json],
 	[AS_HELP_STRING([--without-json], [build without json-c support])],
@@ -935,7 +934,7 @@
                     AC_CHECK_FILE("$JSONDIR/include/json-c/json.h",
                                     JSON_CPPFLAGS="-I$JSONDIR/include/json-c"
-                                    AC_CHECK_LIB([json-c], [json_object_get], [HAVE_JSON_C=yes; JSON_LDFLAGS="${JSON_LDFLAGS} -ljson-c"])
+                                    AC_CHECK_LIB([json-c], [json_object_get], [HAVE_JSON=yes; JSON_LDFLAGS="${JSON_LDFLAGS} -ljson-c"])
                                     AC_CHECK_FILE("$JSONDIR/include/json/json.h",
@@ -949,7 +948,7 @@
             fi
     elif test ! -z "$PKG_CONFIG"; then
 	PKG_CHECK_MODULES([JSONC], [json-c], [
-                HAVE_JSON_C=yes
+                HAVE_JSON=yes
                 JSON_CPPFLAGS="$JSONC_CFLAGS"
                 JSON_LDFLAGS="$JSONC_LIBS"
@@ -958,16 +957,10 @@
     if test "$HAVE_JSON" = "yes"; then
             AC_DEFINE([HAVE_LIBJSON], 1, [Define to 1 if libjson is present])
     fi
-    if test "$HAVE_JSON_C" = "yes"; then
-            AC_DEFINE([HAVE_LIBJSON], 1, [Define to 1 if libjson is present])
-            AC_DEFINE([HAVE_LIBJSON_C], 1, [Define to 1 if libjson resides in a json-c subdir])
-            HAVE_JSON=yes
-    fi
     AC_SUBST([JSON_CPPFLAGS])
     AC_SUBST([JSON_LDFLAGS])
     AC_SUBST([HAVE_JSON])
-    AC_SUBST([HAVE_LIBJSON_C])
 fi
Modified: trunk/liblwgeom/lwin_geojson.c
--- trunk/liblwgeom/lwin_geojson.c	2019-10-08 11:40:36 UTC (rev 17890)
+++ trunk/liblwgeom/lwin_geojson.c	2019-10-08 11:48:33 UTC (rev 17891)
@@ -28,7 +28,7 @@
 #include "lwgeom_log.h"
 #include "../postgis_config.h"
-#if defined(HAVE_LIBJSON) || defined(HAVE_LIBJSON_C) /* --{ */
+#if defined(HAVE_LIBJSON)
 #define JSON_C_VERSION_013 (13 << 8)
@@ -403,7 +403,7 @@
 	return NULL; /* Never reach */
-#endif /* HAVE_LIBJSON or HAVE_LIBJSON_C --} */
+#endif /* HAVE_LIBJSON */
 LWGEOM *
 lwgeom_from_geojson(const char *geojson, char **srs)
@@ -466,5 +466,5 @@
 	lwgeom_add_bbox(lwgeom);
 	return lwgeom;
-#endif /* HAVE_LIBJSON } */
Modified: trunk/postgis/lwgeom_in_geojson.c
--- trunk/postgis/lwgeom_in_geojson.c	2019-10-08 11:40:36 UTC (rev 17890)
+++ trunk/postgis/lwgeom_in_geojson.c	2019-10-08 11:48:33 UTC (rev 17891)
@@ -32,7 +32,7 @@
 #include "liblwgeom.h"
 #include "lwgeom_export.h"
 #include <json.h>
Modified: trunk/postgis_config.h.in
--- trunk/postgis_config.h.in	2019-10-08 11:40:36 UTC (rev 17890)
+++ trunk/postgis_config.h.in	2019-10-08 11:48:33 UTC (rev 17891)
@@ -53,9 +53,6 @@
 /* Define to 1 if libjson is present */
 #undef HAVE_LIBJSON
-/* Define to 1 if libjson resides in json-c subdir */
-#undef HAVE_LIBJSON_C
 /* Define to 1 if you have the `pq' library (-lpq). */
 #undef HAVE_LIBPQ
