[postgis-tickets] [PostGIS] #4532: 3.0.0rc1 build failure on Ubuntu xenial: gserialized_estimate.o: undefined reference to symbol 'roundf@@GLIBC_2.2.5'
PostGIS trac at osgeo.org
Tue Oct 8 09:43:33 PDT 2019
 Reporter:  myon     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.0.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 3.0.0rc1 fails on Ubuntu xenial, all architectures covered by
 apt.postgresql.org. (Other Debian/Ubuntu distributions build fine.)
 amd64:
 13:27:23 gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-
 after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-
 security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -g
 -O2 -fstack-protector-strong -Wformat -Werror=format-security -fPIC -pie
 -fno-omit-frame-pointer -fPIC -shared -o postgis-3.so postgis_module.o
 lwgeom_accum.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o
 lwgeom_inout.o lwgeom_functions_basic.o lwgeom_btree.o lwgeom_box.o
 lwgeom_box3d.o lwgeom_geos.o lwgeom_sfcgal.o lwgeom_geos_prepared.o
 lwgeom_geos_clean.o lwgeom_geos_relatematch.o lwgeom_export.o
 lwgeom_in_gml.o lwgeom_in_kml.o lwgeom_in_geohash.o lwgeom_in_geojson.o
 lwgeom_in_encoded_polyline.o lwgeom_triggers.o lwgeom_dump.o
 lwgeom_dumppoints.o lwgeom_functions_lrs.o lwgeom_functions_temporal.o
 lwgeom_rectree.o long_xact.o lwgeom_sqlmm.o lwgeom_rtree.o
 lwgeom_transform.o lwgeom_window.o gserialized_typmod.o
 gserialized_gist_2d.o gserialized_gist_nd.o gserialized_supportfn.o
 gserialized_spgist_2d.o gserialized_spgist_3d.o gserialized_spgist_nd.o
 brin_2d.o brin_nd.o brin_common.o gserialized_estimate.o geography_inout.o
 geography_btree.o geography_centroid.o geography_measurement.o
 geography_measurement_trees.o geometry_inout.o postgis_libprotobuf.o
 vector_tile.pb-c.o geobuf.pb-c.o mvt.o lwgeom_out_mvt.o geobuf.o
 lwgeom_out_geobuf.o lwgeom_out_geojson.o postgis_legacy.o
 -L/usr/lib/x86_64-linux-gnu  -Wl,-Bsymbolic-functions -Wl,-z,relro
 -Wl,-z,now -L/usr/lib/llvm-6.0/lib  -L/usr/lib/x86_64-linux-gnu/mit-krb5
 -Wl,--as-needed  ../deps/wagyu/libwagyu.la -lstdc++
 ../libpgcommon/libpgcommon.a ../liblwgeom/.libs/liblwgeom.a
 -L/usr/lib/x86_64-linux-gnu -lgeos_c -lproj -ljson-c -lprotobuf-c -lxml2
 -L/usr/lib/x86_64-linux-gnu -lSFCGAL -Wl,--exclude-libs,ALL -Wl
 ,-Bsymbolic-functions -fPIE -pie -Wl,-z,relro -Wl,-z,now -L/usr/lib/x86_64
 -linux-gnu -lSFCGAL
 13:27:24 /usr/bin/ld: gserialized_estimate.o: undefined reference to
 13:27:24 //lib/x86_64-linux-gnu/libm.so.6: error adding symbols: DSO
 missing from command line
 13:27:24 collect2: error: ld returned 1 exit status
 13:27:24
 /usr/lib/postgresql/11/lib/pgxs/src/makefiles/../../src/Makefile.shlib:309:
 recipe for target 'postgis-3.so' failed
 i386 (and ppc64el):
 13:29:32 gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-
 -fPIC -shared -o postgis-3.so postgis_module.o lwgeom_accum.o
 lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_inout.o
 lwgeom_functions_basic.o lwgeom_btree.o lwgeom_box.o lwgeom_box3d.o
 lwgeom_geos.o lwgeom_sfcgal.o lwgeom_geos_prepared.o lwgeom_geos_clean.o
 lwgeom_geos_relatematch.o lwgeom_export.o lwgeom_in_gml.o lwgeom_in_kml.o
 lwgeom_in_geohash.o lwgeom_in_geojson.o lwgeom_in_encoded_polyline.o
 lwgeom_triggers.o lwgeom_dump.o lwgeom_dumppoints.o lwgeom_functions_lrs.o
 lwgeom_functions_temporal.o lwgeom_rectree.o long_xact.o lwgeom_sqlmm.o
 lwgeom_rtree.o lwgeom_transform.o lwgeom_window.o gserialized_typmod.o
 lwgeom_out_geobuf.o lwgeom_out_geojson.o postgis_legacy.o -L/usr/lib/i386
 -linux-gnu  -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-z,now
 -L/usr/lib/llvm-6.0/lib  -L/usr/lib/i386-linux-gnu/mit-krb5 -Wl,--as-
 needed  ../deps/wagyu/libwagyu.la -lstdc++ ../libpgcommon/libpgcommon.a
 ../liblwgeom/.libs/liblwgeom.a  -L/usr/lib/i386-linux-gnu -lgeos_c -lproj
 -ljson-c -lprotobuf-c -lxml2 -L/usr/lib/i386-linux-gnu -lSFCGAL -Wl
 ,--exclude-libs,ALL -Wl,-Bsymbolic-functions -fPIE -pie -Wl,-z,relro
 -Wl,-z,now -L/usr/lib/i386-linux-gnu -lSFCGAL
 13:29:32 /usr/bin/ld: ../liblwgeom/.libs/liblwgeom.a(measures.o):
 undefined reference to symbol 'hypot@@GLIBC_2.0'
 13:29:32 //lib/i386-linux-gnu/libm.so.6: error adding symbols: DSO missing
 from command line
 13:29:32 collect2: error: ld returned 1 exit status
 13:29:32
 Full logs:
 https://pgdgbuild.dus.dg-i.net/view/Binaries/job/postgis-
 binaries/241/architecture=amd64,distribution=xenial/console
 binaries/architecture=i386,distribution=xenial/241/console
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4532>
