[postgis-tickets] r17892 - Fix leak in lwcurvepoly_from_wkb_state
Raul
raul at rmr.ninja
Thu Oct 10 03:10:37 PDT 2019
Author: algunenano
Date: 2019-10-10 03:10:37 -0700 (Thu, 10 Oct 2019)
New Revision: 17892
trunk/NEWS
trunk/liblwgeom/cunit/cu_in_wkb.c
trunk/liblwgeom/lwcurvepoly.c
trunk/liblwgeom/lwin_wkb.c
Closes #4534
Closes https://github.com/postgis/postgis/pull/492
Modified: trunk/NEWS
--- trunk/NEWS 2019-10-08 11:48:33 UTC (rev 17891)
+++ trunk/NEWS 2019-10-10 10:10:37 UTC (rev 17892)
@@ -1,3 +1,14 @@
+PostGIS 3.0.0rc2
+2019/10/XX
+For full changes and enhancements, refer to PostGIS 3.0.0.
+This version requires PostgreSQL 9.5+-12 and GEOS >= 3.6+
+Additional features enabled if you are running Proj6+ and PostgreSQL 12
+Additional performance enhancements if running GEOS 3.8+
+* Major highlights *
+ - #4534, Fix leak in lwcurvepoly_from_wkb_state (Raúl Marín)
PostGIS 3.0.0rc1
2019/10/08
@@ -9,7 +20,7 @@
- #4519, Fix getSRIDbySRS crash (Raúl Marín)
- #4520, Use a clean environment when detecting C++ libraries (Raúl Marín)
- - Restore ST_Union() aggregate signature so drop agg not required and re-work
+ - Restore ST_Union() aggregate signature so drop agg not required and re-work
performance/size enhancement to continue to avoid
using Array type during ST_Union(), hopefully
avoiding Array size limitations. (Paul Ramsey)
Modified: trunk/liblwgeom/cunit/cu_in_wkb.c
--- trunk/liblwgeom/cunit/cu_in_wkb.c 2019-10-08 11:48:33 UTC (rev 17891)
+++ trunk/liblwgeom/cunit/cu_in_wkb.c 2019-10-10 10:10:37 UTC (rev 17892)
@@ -227,6 +227,15 @@
cu_wkb_malformed_in("01060000C00100000001030000C00100000003000000E3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFF");
+static void
+test_wkb_leak(void)
+ /* OSS-FUZZ https://trac.osgeo.org/postgis/ticket/4534 */
+ uint8_t wkb[36] = {000, 000, 000, 000, 015, 000, 000, 000, 003, 000, 200, 000, 000, 010, 000, 000, 000, 000,
+ 000, 000, 000, 000, 010, 000, 000, 000, 000, 000, 000, 000, 000, 010, 000, 000, 000, 000};
+ LWGEOM *g = lwgeom_from_wkb(wkb, 36, LW_PARSER_CHECK_NONE);
+ lwgeom_free(g);
** Used by test harness to register the tests in this file.
@@ -248,4 +257,5 @@
PG_ADD_TEST(suite, test_wkb_in_multicurve);
PG_ADD_TEST(suite, test_wkb_in_multisurface);
PG_ADD_TEST(suite, test_wkb_in_malformed);
+ PG_ADD_TEST(suite, test_wkb_leak);
Modified: trunk/liblwgeom/lwcurvepoly.c
--- trunk/liblwgeom/lwcurvepoly.c 2019-10-08 11:48:33 UTC (rev 17891)
+++ trunk/liblwgeom/lwcurvepoly.c 2019-10-10 10:10:37 UTC (rev 17892)
@@ -84,6 +84,7 @@
LWDEBUG(4,"mismatched nrings/maxrings");
lwerror("Curvepolygon is in inconsistent state. Null memory but non-zero collection counts.");
+ return LW_FAILURE;
/* Check that we're adding an allowed ring type */
Modified: trunk/liblwgeom/lwin_wkb.c
--- trunk/liblwgeom/lwin_wkb.c 2019-10-08 11:48:33 UTC (rev 17891)
+++ trunk/liblwgeom/lwin_wkb.c 2019-10-10 10:10:37 UTC (rev 17892)
@@ -618,7 +618,12 @@
geom = lwgeom_from_wkb_state(s);
if ( lwcurvepoly_add_ring(cp, geom) == LW_FAILURE )
+ lwgeom_free(geom);
+ lwgeom_free((LWGEOM *)cp);
lwerror("Unable to add geometry (%p) to curvepoly (%p)", geom, cp);
+ return NULL;
return cp;
