[postgis-tickets] r17895 - Fix leak in lwcurvepoly_from_wkb_state
Raul raul at rmr.ninja
Thu Oct 10 04:39:01 PDT 2019
Author: algunenano
Date: 2019-10-10 04:39:01 -0700 (Thu, 10 Oct 2019)
New Revision: 17895
   branches/2.4/NEWS
   branches/2.4/liblwgeom/cunit/cu_in_wkb.c
   branches/2.4/liblwgeom/lwcurvepoly.c
   branches/2.4/liblwgeom/lwin_wkb.c
References #4534
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS	2019-10-10 11:37:54 UTC (rev 17894)
+++ branches/2.4/NEWS	2019-10-10 11:39:01 UTC (rev 17895)
@@ -13,6 +13,7 @@
   - #4506, Remove tolerance in point-in-ring stabline tests (Paul Ramsey)
   - #4518, Backport system views to make upgrade to PostGIS3 cleaner (Paul Ramsey)
   - #4519, Fix getSRIDbySRS crash (Raúl Marín)
+  - #4534, Fix leak in lwcurvepoly_from_wkb_state (Raúl Marín)
 PostGIS 2.4.8
Modified: branches/2.4/liblwgeom/cunit/cu_in_wkb.c
--- branches/2.4/liblwgeom/cunit/cu_in_wkb.c	2019-10-10 11:37:54 UTC (rev 17894)
+++ branches/2.4/liblwgeom/cunit/cu_in_wkb.c	2019-10-10 11:39:01 UTC (rev 17895)
@@ -223,6 +223,15 @@
 	cu_wkb_malformed_in("01060000C00100000001030000C00100000003000000E3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFF");
+static void
+test_wkb_leak(void)
+	/* OSS-FUZZ https://trac.osgeo.org/postgis/ticket/4534 */
+	uint8_t wkb[36] = {000, 000, 000, 000, 015, 000, 000, 000, 003, 000, 200, 000, 000, 010, 000, 000, 000, 000,
+			   000, 000, 000, 000, 010, 000, 000, 000, 000, 000, 000, 000, 000, 010, 000, 000, 000, 000};
+	LWGEOM *g = lwgeom_from_wkb(wkb, 36, LW_PARSER_CHECK_NONE);
+	lwgeom_free(g);
 ** Used by test harness to register the tests in this file.
@@ -244,4 +253,5 @@
 	PG_ADD_TEST(suite, test_wkb_in_multicurve);
 	PG_ADD_TEST(suite, test_wkb_in_multisurface);
 	PG_ADD_TEST(suite, test_wkb_in_malformed);
+	PG_ADD_TEST(suite, test_wkb_leak);
Modified: branches/2.4/liblwgeom/lwcurvepoly.c
--- branches/2.4/liblwgeom/lwcurvepoly.c	2019-10-10 11:37:54 UTC (rev 17894)
+++ branches/2.4/liblwgeom/lwcurvepoly.c	2019-10-10 11:39:01 UTC (rev 17895)
@@ -85,6 +85,7 @@
 		LWDEBUG(4,"mismatched nrings/maxrings");
 		lwerror("Curvepolygon is in inconsistent state. Null memory but non-zero collection counts.");
+		return LW_FAILURE;
 	/* Check that we're adding an allowed ring type */
Modified: branches/2.4/liblwgeom/lwin_wkb.c
--- branches/2.4/liblwgeom/lwin_wkb.c	2019-10-10 11:37:54 UTC (rev 17894)
+++ branches/2.4/liblwgeom/lwin_wkb.c	2019-10-10 11:39:01 UTC (rev 17895)
@@ -613,7 +613,12 @@
 		geom = lwgeom_from_wkb_state(s);
 		if ( lwcurvepoly_add_ring(cp, geom) == LW_FAILURE )
+			lwgeom_free(geom);
+			lwgeom_free((LWGEOM *)cp);
 			lwerror("Unable to add geometry (%p) to curvepoly (%p)", geom, cp);
+			return NULL;
 	return cp;
