[postgis-tickets] r17896 - Fix leak in lwcurvepoly_from_wkb_state
Raul
raul at rmr.ninja
Thu Oct 10 04:39:48 PDT 2019
Author: algunenano
Date: 2019-10-10 04:39:48 -0700 (Thu, 10 Oct 2019)
New Revision: 17896
branches/2.3/NEWS
branches/2.3/liblwgeom/cunit/cu_in_wkb.c
branches/2.3/liblwgeom/lwcurvepoly.c
branches/2.3/liblwgeom/lwin_wkb.c
References #4534
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS 2019-10-10 11:39:01 UTC (rev 17895)
+++ branches/2.3/NEWS 2019-10-10 11:39:48 UTC (rev 17896)
@@ -10,6 +10,7 @@
- #4495, Fix ST_SnapToGrid output having an outdated bbox (Raúl Marín)
- #4498, Restrict build for PgSQL > 9.6
- #4519, Fix getSRIDbySRS crash (Raúl Marín)
+ - #4534, Fix leak in lwcurvepoly_from_wkb_state (Raúl Marín)
PostGIS 2.3.10
2019/08/11
Modified: branches/2.3/liblwgeom/cunit/cu_in_wkb.c
--- branches/2.3/liblwgeom/cunit/cu_in_wkb.c 2019-10-10 11:39:01 UTC (rev 17895)
+++ branches/2.3/liblwgeom/cunit/cu_in_wkb.c 2019-10-10 11:39:48 UTC (rev 17896)
@@ -223,6 +223,15 @@
cu_wkb_malformed_in("01060000C00100000001030000C00100000003000000E3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFF");
+static void
+test_wkb_leak(void)
+ /* OSS-FUZZ https://trac.osgeo.org/postgis/ticket/4534 */
+ uint8_t wkb[36] = {000, 000, 000, 000, 015, 000, 000, 000, 003, 000, 200, 000, 000, 010, 000, 000, 000, 000,
+ 000, 000, 000, 000, 010, 000, 000, 000, 000, 000, 000, 000, 000, 010, 000, 000, 000, 000};
+ LWGEOM *g = lwgeom_from_wkb(wkb, 36, LW_PARSER_CHECK_NONE);
+ lwgeom_free(g);
** Used by test harness to register the tests in this file.
@@ -244,4 +253,5 @@
PG_ADD_TEST(suite, test_wkb_in_multicurve);
PG_ADD_TEST(suite, test_wkb_in_multisurface);
PG_ADD_TEST(suite, test_wkb_in_malformed);
+ PG_ADD_TEST(suite, test_wkb_leak);
Modified: branches/2.3/liblwgeom/lwcurvepoly.c
--- branches/2.3/liblwgeom/lwcurvepoly.c 2019-10-10 11:39:01 UTC (rev 17895)
+++ branches/2.3/liblwgeom/lwcurvepoly.c 2019-10-10 11:39:48 UTC (rev 17896)
@@ -85,6 +85,7 @@
LWDEBUG(4,"mismatched nrings/maxrings");
lwerror("Curvepolygon is in inconsistent state. Null memory but non-zero collection counts.");
+ return LW_FAILURE;
/* Check that we're adding an allowed ring type */
Modified: branches/2.3/liblwgeom/lwin_wkb.c
--- branches/2.3/liblwgeom/lwin_wkb.c 2019-10-10 11:39:01 UTC (rev 17895)
+++ branches/2.3/liblwgeom/lwin_wkb.c 2019-10-10 11:39:48 UTC (rev 17896)
@@ -613,7 +613,12 @@
geom = lwgeom_from_wkb_state(s);
if ( lwcurvepoly_add_ring(cp, geom) == LW_FAILURE )
+ lwgeom_free(geom);
+ lwgeom_free((LWGEOM *)cp);
lwerror("Unable to add geometry (%p) to curvepoly (%p)", geom, cp);
+ return NULL;
return cp;
