[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. 19202c260ca9d5440899a3c0215f8c233845f350
git at osgeo.org
git at osgeo.org
Thu Oct 10 11:58:57 PDT 2019
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
via 19202c260ca9d5440899a3c0215f8c233845f350 (commit)
from 846301959476eb31cf19dd70d06dddcbdfb3ba56 (commit)
revisions in full, below.
commit 19202c260ca9d5440899a3c0215f8c233845f350
Author: Regina Obe <lr at pcorp.us>
Date: Thu Oct 10 14:58:53 2019 -0400
Revise to allow inlining to be overridden
diff --git a/.vscode/settings.json b/.vscode/settings.json
new file mode 100644
index 0000000..266f020
--- /dev/null
+++ b/.vscode/settings.json
@@ -0,0 +1,3 @@
+ "terminal.explorerKind": "external"
\ No newline at end of file
diff --git a/windows/mingw64/scripts/geos_make_install_check_branch.sh b/windows/mingw64/scripts/geos_make_install_check_branch.sh
index 6b9eb39..b279125 100644
--- a/windows/mingw64/scripts/geos_make_install_check_branch.sh
+++ b/windows/mingw64/scripts/geos_make_install_check_branch.sh
@@ -49,14 +49,18 @@ if [[ "$MAKE_TYPE" == *cmake* ]] ; then
rm -rf build${OS_BUILD}${MAKE_TYPE}
mkdir -p build${OS_BUILD}${MAKE_TYPE}
cd build${OS_BUILD}${MAKE_TYPE}
+ export GEOS_ENABLE_INLINE=ON #for older geos
+ if [["${DISABLE_GEOS_INLINE}"]]; then
+ export DISABLE_GEOS_INLINE=ON
+ fi
- if [[ "${OS_BUILD}" == "64" ]] ; then
- #cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DHAVE_LONG_LONG_INT_64=1 -DGEOS_ENABLE_INLINE=NO -DDISABLE_GEOS_INLINE=ON - ../${CMAKE_GEOS_VER}
- cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DHAVE_LONG_LONG_INT_64=1 - ../${CMAKE_GEOS_VER}
- else
- #cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DGEOS_ENABLE_INLINE=NO -DDISABLE_GEOS_INLINE=ON - ../${CMAKE_GEOS_VER}
- cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 - ../${CMAKE_GEOS_VER}
- fi
+ if [[ "${OS_BUILD}" == "64" ]] ; then
+ #cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DHAVE_LONG_LONG_INT_64=1 -DGEOS_ENABLE_INLINE=NO -DDISABLE_GEOS_INLINE=ON - ../${CMAKE_GEOS_VER}
+ cmake -G "MSYS Makefiles" -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DHAVE_LONG_LONG_INT_64=1 -DGEOS_ENABLE_INLINE=${GEOS_ENABLE_INLINE} -DDISABLE_GEOS_INLINE=${DISABLE_GEOS_INLINE} - ../${CMAKE_GEOS_VER}
+ else
+ #cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DGEOS_ENABLE_INLINE=NO -DDISABLE_GEOS_INLINE=ON - ../${CMAKE_GEOS_VER}
+ cmake -G "MSYS Makefiles" -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DGEOS_ENABLE_INLINE=${GEOS_ENABLE_INLINE} -DDISABLE_GEOS_INLINE=${DISABLE_GEOS_INLINE} - ../${CMAKE_GEOS_VER}
+ fi
make && make install
#make check
ctest --output-on-failure
Summary of changes:
.vscode/settings.json | 3 +++
.../mingw64/scripts/geos_make_install_check_branch.sh | 18 +++++++++++-------
2 files changed, 14 insertions(+), 7 deletions(-)
create mode 100644 .vscode/settings.json
hooks/post-receive
