[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. a839352812f1d6f76705cf7f6f75dd0d118ef280
git at osgeo.org
git at osgeo.org
Thu Oct 10 13:34:50 PDT 2019
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
via a839352812f1d6f76705cf7f6f75dd0d118ef280 (commit)
from 19202c260ca9d5440899a3c0215f8c233845f350 (commit)
revisions in full, below.
commit a839352812f1d6f76705cf7f6f75dd0d118ef280
Author: Regina Obe <lr at pcorp.us>
Date: Thu Oct 10 16:34:46 2019 -0400
echo disable inline setting
diff --git a/windows/mingw64/scripts/geos_make_install_check_branch.sh b/windows/mingw64/scripts/geos_make_install_check_branch.sh
index b279125..f2d4923 100644
--- a/windows/mingw64/scripts/geos_make_install_check_branch.sh
+++ b/windows/mingw64/scripts/geos_make_install_check_branch.sh
@@ -50,9 +50,10 @@ if [[ "$MAKE_TYPE" == *cmake* ]] ; then
mkdir -p build${OS_BUILD}${MAKE_TYPE}
cd build${OS_BUILD}${MAKE_TYPE}
export GEOS_ENABLE_INLINE=ON #for older geos
- if [["${DISABLE_GEOS_INLINE}"]]; then
+ if [["${DISABLE_GEOS_INLINE}" == '']]; then
export DISABLE_GEOS_INLINE=ON
fi
+ echo "Disable geos inline ${DISABLE_GEOS_INLINE}"
if [[ "${OS_BUILD}" == "64" ]] ; then
#cmake -G "MSYS Makefiles" DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE} -DHAVE_STD_ISNAN=1 -DHAVE_LONG_LONG_INT_64=1 -DGEOS_ENABLE_INLINE=NO -DDISABLE_GEOS_INLINE=ON - ../${CMAKE_GEOS_VER}
Summary of changes:
windows/mingw64/scripts/geos_make_install_check_branch.sh | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
hooks/post-receive
