[postgis-tickets] [PostGIS] #4550: st_asmvtgeom sometimes returns null for valid geometries (postgis 2.5.3)
trac at osgeo.org
Thu Oct 17 12:43:00 PDT 2019
Reporter: anneb | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.4
Component: postgis | Version: 2.5.x
Keywords: st_asmvtgeom |
in PostGIS 2.5.3, function st_asMVTGeom sometimes returns NULL for valid
(but complicated) polygon geometries. The problem depends on the zoom-
level. Apparently, the problem occurs with some levels of simplification.
On other zoom-levels, the same source geometry is output correctly to as
mvt.
example of the problem (in tile z=7, x=66, y=42):
with data as
(select st_geomfromewkt('SRID=3857;MULTIPOLYGON(((725189.152109922
6815047.4380655,725313.493934068 6814594.30359714,725255.113930394
6815000.20381502,725326.659505309 6814567.13706215,725376.325951706
6814473.11001708,725323.05983762 6814562.79542736,725337.107185082
6814482.96470687,725455.242593412 6814194.32538979,725373.040398379
6814174.06448492,725453.765899427 6813976.80692352,724958.276702709
6813976.80692352,724958.276702709 6815047.4380655,725189.152109922
6815047.4380655)),((725251.633972098 6815032.51269983,725453.685664168
6815047.4380655,725553.665184441 6814604.72817644,725375.473761016
6814574.45666661,725279.127438692 6814977.08584902,725332.798208279
6814566.38845648,725251.633972098 6815032.51269983)))') as geom)
select st_isvalid(geom),
geom as inputgeom,
st_asmvtgeom(geom,
ST_MakeBox2D(ST_Point(626172.1357121639, 6574807.4249777235),
ST_Point(939258.2035682457, 6887893.492833804))) as nullgeom,
st_asmvtgeom(st_simplifypreservetopology(geom, 50),
6574807.4249777235), ST_Point(939258.2035682457, 6887893.492833804))) as
simplifiedgeom
from data;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4550>
