[postgis-tickets] r17951 - Use get_call_result_type to retrieve tuple descriptions
Raul
raul at rmr.ninja
Fri Oct 18 01:42:30 PDT 2019
Author: algunenano
Date: 2019-10-18 01:42:28 -0700 (Fri, 18 Oct 2019)
New Revision: 17951
trunk/postgis/lwgeom_dump.c
trunk/postgis/lwgeom_geos.c
Closes #499
References #4549
References #4546
Modified: trunk/postgis/lwgeom_dump.c
--- trunk/postgis/lwgeom_dump.c 2019-10-18 02:18:50 UTC (rev 17950)
+++ trunk/postgis/lwgeom_dump.c 2019-10-18 08:42:28 UTC (rev 17951)
@@ -117,7 +117,8 @@
* Build a tuple description for an
* geometry_dump tuple
- tupdesc = RelationNameGetTupleDesc("geometry_dump");
+ get_call_result_type(fcinfo, 0, &tupdesc);
+ BlessTupleDesc(tupdesc);
* generate attribute metadata needed later to produce
@@ -255,7 +256,8 @@
Modified: trunk/postgis/lwgeom_geos.c
--- trunk/postgis/lwgeom_geos.c 2019-10-18 02:18:50 UTC (rev 17950)
+++ trunk/postgis/lwgeom_geos.c 2019-10-18 08:42:28 UTC (rev 17951)
@@ -1530,12 +1530,8 @@
* valid_detail tuple
- tupdesc = RelationNameGetTupleDesc("valid_detail");
- if ( ! tupdesc )
- lwpgerror("TYPE valid_detail not found");
- PG_RETURN_NULL();
