[postgis-tickets] [PostGIS] #499: [wktraster] -M vacuum switch of gdal2wktraster doesn't work with schemas
PostGIS trac at osgeo.org
Fri Oct 18 01:42:35 PDT 2019
  Reporter:  robe    |      Owner:  pracine
      Type:  defect  |     Status:  closed
  Priority:  medium  |  Milestone:  WKTRaster 0.1.6
 Component:  raster  |    Version:  trunk
Resolution:  fixed   |   Keywords:
Comment (by Raul Marin):
 In [changeset:"17951" 17951]:
 #!CommitTicketReference repository="" revision="17951"
 Use get_call_result_type to retrieve tuple descriptions
 Closes #499
 References #4549
 References #4546
Ticket URL: <https://trac.osgeo.org/postgis/ticket/499#comment:2>
