[postgis-tickets] [PostGIS] #4504: -D copy mode not working with schema qualified tables
PostGIS trac at osgeo.org
Sun Sep 8 23:21:00 PDT 2019
 Reporter:  robe           |      Owner:  robe
     Type:  defect         |     Status:  assigned
 Priority:  blocker        |  Milestone:  PostGIS 3.0.0
Component:  loader/dumper  |    Version:  trunk
 Keywords:                 |
 I must have broke this when I put in transform logic for copy mode
 shp2pgsql -D -s 4269 -g geom -I /data/roadtrl020.shp ch01.roads
 Produces invalid sql.
 ALTER TABLE "ch01"."roads" ADD PRIMARY KEY (gid);
 SELECT
 AddGeometryColumn('ch01','roads','geom','4269','MULTILINESTRING',2);
 COPY  "ch01"."  "roads"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4504>
