[postgis-tickets] [PostGIS] #4504: -D copy mode not working with schema qualified tables
    trac at osgeo.org
    Fri Sep 13 14:14:15 PDT 2019
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  closed
  Priority:  blocker        |  Milestone:  PostGIS 3.0.0
 Component:  loader/dumper  |    Version:  trunk
Resolution:  fixed          |   Keywords:
Changes (by robe):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17809" 17809]:
 #!CommitTicketReference repository="" revision="17809"
 shp2pgsql -D not working with schema qualified tables
 Closes #4504
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4504#comment:1>
