[postgis-tickets] [PostGIS] #4508: Regression Failures at r17812
trac at osgeo.org
Mon Sep 16 15:50:04 PDT 2019
Reporter: pramsey | Owner: Algunenano
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
From the tests failing, I suspect the source is the repeated points / MVT
work recently committed.
--- snaptogrid_expected 2019-09-03 19:53:59.000000000 -0700
+++ /tmp/pgis_reg/test_89_out 2019-09-16 15:41:16.000000000 -0700
@@ -3,5 +3,5 @@
t
t
t
-POLYGON((0 0,10 0,10 10,0 10,0 0))|BOX(0 0,10 10)
+POLYGON((0 0,10 0,10 10,0 10,0 0))|BOX(0 0,10.6000003814697 10.5)
and
--- remove_repeated_points_expected 2019-09-03 19:53:59.000000000 -0700
+++ /tmp/pgis_reg/test_82_out 2019-09-16 15:41:15.000000000 -0700
@@ -17,4 +17,4 @@
16|MULTIPOINT(0 0,1 1,2 2)
17|MULTIPOINT(0 0,4 4)
18|POLYGON((-215922 5325694,-218693 5322119,-216112 5325812,-215922
5325694))
-19|POLYGON((0 0,10 0,10 10,0 10,0 0))|BOX(0 0,10 10)
+19|POLYGON((0 0,10 0,10 10,0 10,0 0))|BOX(0 0,10.5 10.5)
and
--- measures_expected 2019-09-03 19:53:59.000000000 -0700
+++ /tmp/pgis_reg/test_57_out 2019-09-16 15:41:02.000000000 -0700
@@ -68,14 +68,14 @@
#4278.3|f
#4278.4|1
NOTICE: One or both of the geometries is missing z-value. The unknown
z-value will be regarded as "any value"
-#4328.1|t|t
+ERROR: lw_dist2d_distribute_bruteforce: Unsupported geometry type: Tin
-#4328.2|t|t
-#4328.3|t|t
-#4328.4|t|t
-#4328.5|t|t
-#4328.6|t|t
the last one looks like komzpa.
Darwin Sparrow.local 18.7.0 Darwin Kernel Version 18.7.0: Tue Aug 20
16:57:14 PDT 2019; root:xnu-4903.271.2~2/RELEASE_X86_64 x86_64
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4508>
