[postgis-tickets] [PostGIS] #4508: Regression Failures at r17812
PostGIS trac at osgeo.org
Mon Sep 16 18:23:32 PDT 2019
  Reporter:  pramsey  |      Owner:  Algunenano
      Type:  defect   |     Status:  assigned
  Priority:  high     |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by Algunenano):
 First and second point to the bbox not being refreshed in your
 environment, which is odd. I'd have expected to break the repeated points
 function with the speed up changes, but all I did to snap2grid was to add
 the refresh call and add those tests.
 Also todays changes (the speed up) moved the bbox drop to liblwgeom
 instead of postgis, so it's even stranger.
 The 3rd error looks also points to a possibly outdated liblwgeom
 Can you confirm you are testing with HEAD and a clean environment, please?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4508#comment:1>
