[postgis-tickets] [PostGIS] #4508: Regression Failures at r17812
trac at osgeo.org
Tue Sep 17 03:10:45 PDT 2019
Reporter: pramsey | Owner: Algunenano
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by Algunenano):
I couldn't reproduce this in OSX:
Darwin rs-iMac.local 18.2.0 Darwin Kernel Version 18.2.0: Thu Dec 20
20:46:53 PST 2018; root:xnu-4903.241.1~1/RELEASE_X86_64 x86_64
GEOS config: /usr/local/bin/geos-config
GEOS version: 3.7.2
GDAL config: /usr/local/bin/gdal-config
GDAL version: 2.4.2
SFCGAL config: /usr/local/bin/sfcgal-config
SFCGAL version: 1.3.7
PostgreSQL config: /usr/local/bin/pg_config
PostgreSQL version: PostgreSQL 11.5
PROJ4 version: 62
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.9.4
Tests are also passing with Debian buster 32bit.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4508#comment:2>
