[postgis-tickets] [PostGIS] #4508: Regression Failures at r17812
trac at osgeo.org
Tue Sep 17 09:49:24 PDT 2019
Reporter: pramsey | Owner: Algunenano
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by pramsey):
I think I have a bum build, I just rebuilt on a separate machine and have
clean results. I think, once again, I'm seeing the effect of liblwgeom,
and my 'make check' is picking up an old liblwgeom instead of the one in
the build tree. I bet if I do 'make install' and then 'make check' my
problems will disappear.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4508#comment:3>
