[postgis-tickets] [PostGIS] #4508: Regression Failures at r17812
trac at osgeo.org
Tue Sep 17 09:52:44 PDT 2019
Reporter: pramsey | Owner: Algunenano
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by pramsey):
* status: assigned => closed
* resolution: => fixed
Comment:
Yep, confirmed. Now if only I could figure out why postgis, which is
supposed to statically link against the local copy of liblwgeom instead
ends up running against the copy in /usr/local/lib.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4508#comment:4>
