[postgis-tickets] [PostGIS] #4511: PG 13 failing: could not find attribute 2 in subquery targetlist
trac at osgeo.org
Tue Sep 24 04:43:42 PDT 2019
Reporter: Algunenano | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS PostgreSQL
Component: postgis | Version: trunk
Keywords: |
The PG13 build is failing with (https://travis-
ci.org/postgis/postgis/jobs/588883186):
--- tickets_expected 2019-09-24 10:39:48.000000000 +0000
+++ /tmp/pgis_reg/test_102_out 2019-09-24 10:43:38.336906785 +0000
@@ -264,7 +264,7 @@
#2704|POLYGON((0 0,0 1,1 1,1 0,0 0))
#2712|LINESTRING EMPTY
#2717|POINT(-1 -1)|POINT(3 1)|POINT(-1 -1)|POINT(1 1)|POINT(1 1)|POINT(2
2)|POINT(3 1)
-#2788|f|Self-intersection|POINT(1 1)
+ERROR: could not find attribute 2 in subquery targetlist
#2870|Point[GS]
#2956|t
#2985|LINESTRING(20.9511664253809 52.3984560730436)
I've tracked it down to a recent PG commit:
https://git.postgresql.org/gitweb/?p=postgresql.git;a=commitdiff;h=7266d0997dd2a0632da38a594c78e25ff21df67e
The main thread is in https://www.postgresql.org/message-
id/flat/402356c32eeb93d4fed01f66d6c7fe2d%40postgrespro.ru
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4511>
