[postgis-tickets] [PostGIS] #4512: Dependency on xsltproc is critical to produce postgis.control
PostGIS trac at osgeo.org
Tue Sep 24 05:18:44 PDT 2019
 Reporter:  evgen    |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.0.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 I tried to build posgis-3.0
 commit(a6bb23c883c317a50eed9a22ac2faf178c8fe90a) from sources.
 `./configure` allowed to build postgis without xsltproc. See output below.
 Then `make -j` compiled everything successfully without issues. And `sudo
 make install` installed it without single warning. However `alter
 extension postgis update;` returned an error:
 `ERROR:  could not open extension control file
 "/usr/share/postgresql/10/extension/postgis.control": No such file or
 directory`
 When I installed xsltproc, launched configure, make, sudo make install
 again - postgis.control appears in place along with all required sql
 files.
 `./configure` output without xsltproc:
 PostGIS is now configured for x86_64-pc-linux-gnu
 -------------- Compiler Info -------------
   C compiler:           gcc -std=gnu99 -g -O2 -fno-math-errno -fno-signed-
 zeros
   CPPFLAGS:              -I/usr/include   -I/usr/include/libxml2
 -I/usr/include/json-c
   SQL preprocessor:     /usr/bin/cpp -traditional-cpp -w -P
  -------------- Additional Info -------------
   Interrupt Tests:   DISABLED use: --with-interrupt-tests to enable
  -------------- Dependencies --------------
   GEOS config:          /usr/bin/geos-config
   GEOS version:         3.6.2
   GDAL config:          /usr/bin/gdal-config
   GDAL version:         2.2.3
   PostgreSQL config:    /usr/bin/pg_config
   PostgreSQL version:   PostgreSQL 10.10 (Ubuntu 10.10-0ubuntu0.18.04.1)
   PROJ4 version:        49
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.9.4
   JSON-C support:       yes
   protobuf-c support:   no
   PCRE support:         yes
   Perl:                 /usr/bin/perl
   Wagyu:                no
  --------------- Extensions ---------------
   PostGIS Raster:                     enabled
   PostGIS Topology:                   enabled
   SFCGAL support:                     disabled
   Address Standardizer support:       enabled
  -------- Documentation Generation --------
   xsltproc:
   xsl style sheets:
   dblatex:
   convert:
   mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
 configure: WARNING:  --------- GEOS VERSION WARNING ------------
 configure: WARNING:   You are building against GEOS 3.6.2.
 configure: WARNING:
 configure: WARNING:   To take advantage of _all_ the features of
 configure: WARNING:   PostGIS, GEOS 3.7.0 or higher is required.
 configure: WARNING:
 configure: WARNING:   For _most_ features, GEOS 3.6.0 is enough.
 configure: WARNING:
 configure: WARNING:   We recommend GEOS 3.7.0 or higher
 configure: WARNING:
 configure: WARNING:   You can download the latest versions from
 configure: WARNING:   http://geos.osgeo.org/
 configure: WARNING:
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4512>
