[postgis-tickets] [PostGIS] #4512: Dependency on xsltproc is critical to produce postgis.control
trac at osgeo.org
Fri Sep 27 20:00:22 PDT 2019
Reporter: evgen | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
It's only critical if you are building from svn or git. If you build from
tarball, the comments are already generated, so you shouldn't need
xsltproc.
Were you building from tarball or one of our repos?
This has come up before but maybe it was closed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4512#comment:1>
