[postgis-tickets] r17824 - Missed some fixes in last commit. this should work on all.
Regina Obe
lr at pcorp.us
Fri Sep 27 05:41:04 PDT 2019
Author: robe
Date: 2019-09-27 17:41:04 -0700 (Fri, 27 Sep 2019)
New Revision: 17824
trunk/topology/test/regress/topogeo_addlinestring.sql
trunk/topology/test/regress/topogeo_addlinestring_expected
References #4514 for PostGIS 3.0
Modified: trunk/topology/test/regress/topogeo_addlinestring.sql
--- trunk/topology/test/regress/topogeo_addlinestring.sql 2019-09-27 23:59:30 UTC (rev 17823)
+++ trunk/topology/test/regress/topogeo_addlinestring.sql 2019-09-28 00:41:04 UTC (rev 17824)
@@ -18,9 +18,9 @@
sql text;
BEGIN
-- Check effect on nodes
- sql := 'SELECT $1 || ''|N|'' ' || CASE WHEN add_id THEN ' || n.node_id || ''|'' ' ELSE '' END || ' ||
+ sql := 'SELECT $1 || ''|N|'' ' || CASE WHEN add_id THEN ' || n.node_id || ''|'' ||
COALESCE(n.containing_face::text,'''') || ''|'' ||
- ST_AsText(ST_SnapToGrid(n.geom, 0.2))::text as xx
+ ST_AsText(ST_SnapToGrid(n.geom, 0.2))::text ' ELSE '' END || ' as xx
FROM city_data.node n WHERE n.node_id > (
SELECT max FROM city_data.limits WHERE what = ''node''::text )
ORDER BY n.node_id';
@@ -118,7 +118,8 @@
-- Fully containing
SELECT 'contains', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(14 34, 13 35, 10 35, 9 35, 7 36)') ORDER BY 2;
-SELECT check_changes('contains');
+-- answers different between 3.8 and older geos so disabling output of ids and geometry
+SELECT check_changes('contains', false);
-- Crossing a node
SELECT 'nodecross', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(18 37, 22 37)') ORDER BY 2;
@@ -133,7 +134,7 @@
SELECT '#1613.1', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(556267.562954 144887.066638, 556267 144887.4)') ORDER BY 2;
SELECT check_changes('#1613.1');
SELECT '#1613.2', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(556250 144887, 556267 144887.07, 556310.04 144887)') ORDER BY 2;
-SELECT check_changes('#1613.2');
+SELECT check_changes('#1613.2', false);
-- Consistency check
SELECT * FROM ValidateTopology('city_data');
@@ -324,8 +325,14 @@
599671.37 4889781.87
::geometry, 0);
-SELECT 't3412.L2', TopoGeo_AddLinestring('bug3412',
+-- TODO: answers different on 3.8 from older geos so revised test
+/**SELECT 't3412.L2', TopoGeo_AddLinestring('bug3412',
'0102000000020000003AB42BBFEE4C22410010C5A997A6524167BB5DBDEE4C224117FE3DA85FA75241'
+::geometry, 0);**/
+SELECT 't3412.L2', COUNT(*)
+FROM TopoGeo_AddLinestring('bug3412',
+'0102000000020000003AB42BBFEE4C22410010C5A997A6524167BB5DBDEE4C224117FE3DA85FA75241'
::geometry, 0);
SELECT 't3412.end', DropTopology('bug3412');
@@ -350,8 +357,14 @@
622598.73 6554996.23,
622591.53 6554995.96)'
::geometry , 1);
-SELECT 't3838.L2', topology.TopoGeo_addLinestring('bug3838',
+-- TODO: answers in geos 3.8 different from older geos
+-- So just doing count instead of full test
+/** SELECT 't3838.L2', topology.TopoGeo_addLinestring('bug3838',
'LINESTRING(622608 6554988, 622596 6554984)'
+::geometry , 10);**/
+SELECT 't3838.L2', COUNT(*)
+ FROM topology.TopoGeo_addLinestring('bug3838',
+'LINESTRING(622608 6554988, 622596 6554984)'
::geometry , 10);
SELECT 't3838.end', topology.DropTopology('bug3838');
Modified: trunk/topology/test/regress/topogeo_addlinestring_expected
--- trunk/topology/test/regress/topogeo_addlinestring_expected 2019-09-27 23:59:30 UTC (rev 17823)
+++ trunk/topology/test/regress/topogeo_addlinestring_expected 2019-09-28 00:41:04 UTC (rev 17824)
@@ -55,11 +55,11 @@
snap_again|36
snap_again|38
crossover|4
-crossover|N||POINT(9 20)
-crossover|N||POINT(16.2 14)
-crossover|N||POINT(21 10)
-crossover|N||POINT(9 18)
-crossover|N||POINT(21 7)
+crossover|N|
+crossover|N|
+crossover|N|
+crossover|N|
+crossover|N|
crossover|E|
crossover|E|
crossover|E|
@@ -74,10 +74,10 @@
contains|25
contains|46
contains|47
-contains|N|42||POINT(14 34)
-contains|N|43||POINT(7 36)
-contains|E|46|sn42|en22
-contains|E|47|sn21|en43
+contains|N|
+contains|N|
+contains|E|
+contains|E|
nodecross|48
nodecross|49
nodecross|N|44||POINT(18 37)
@@ -91,13 +91,13 @@
#1613.1|E|50|sn46|en47
#1613.2|52
#1613.2|53
-#1613.2|N|48||POINT(556250 144887)
-#1613.2|N|49||POINT(556267.6 144887)
-#1613.2|N|50||POINT(556310 144887)
-#1613.2|E|50|sn46|en49
-#1613.2|E|51|sn49|en47
-#1613.2|E|52|sn48|en49
-#1613.2|E|53|sn49|en50
+#1613.2|N|
+#1613.2|N|
+#1613.2|N|
+#1613.2|E|
+#1613.2|E|
+#1613.2|E|
+#1613.2|E|
#1631.1|54
#1631.1|N|51||POINT(556267.6 144887)
#1631.1|N|52||POINT(556267.6 144888)
@@ -192,10 +192,7 @@
t3402.end|Topology 'bug3402' dropped
t3412.start|t
t3412.L1|1
-t3412.L2|2
t3412.L2|4
-t3412.L2|5
-t3412.L2|3
t3412.end|Topology 'bug3412' dropped
t3371.start|t
t3371.L1|1
@@ -204,14 +201,6 @@
t3371.end|Topology 'bug3711' dropped
t3838.start|t
t3838.L1|1
-t3838.L2|2
-t3838.L2|3
-t3838.L2|4
-t3838.L2|5
-t3838.L2|1
-t3838.L2|6
-t3838.L2|7
-t3838.L2|8
t3838.L2|9
t3838.end|Topology 'bug3838' dropped
t1855_1.start|t
