[postgis-tickets] [PostGIS] #3821: Don't drop st_union when updating postgis extension to 2.4
trac at osgeo.org
Fri Sep 27 06:35:51 PDT 2019
Reporter: nextstopsun | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: 2.3.x
Resolution: fixed | Keywords:
Comment (by dmkaplan2000):
Replying to [comment:11 robe]:
I know this has been closed for a while, but I am running into this
problem upgrading from Postgis 2.4.3 to Postgis 2.5.2 on a Postgresql 10
cluster on Ubuntu. I have desperately been trying to implement your
solution of simply not dropping the ST_Union(geometry) aggregate, but I am
obviously not editing the correct script as it has been having no effect.
Would you mind indicating the correct file to edit? I have tried editing:
/usr/share/postgresql/10/extension/postgis--ANY--2.5.2.sql
/usr/share/postgresql/10/contrib/postgis-2.5/postgis_upgrade_for_extension.sql
as well as several other similar file, but nothing seems to happen.
Thanks!
> Sadly I'm afraid since we don't keep track of changes within dev, going
from PostGIS 2.4.0dev to PostGIS 2.4.0devnext for example will always try
to drop and recreate the aggs. Fussing with sys catalogs is beginning to
feel more appealing to me now.
> What you could do for now if you really don't want to drop and recreate
the aggs (or you just need to do it for ST_Union) , is in the extension
scripts -- e.g. postgis--2.4.0devnext--2.4.0dev.sql
> where it has
> OR (
> 204 = version_from_num AND version_from_isdev
> Wipe that out and it won't force drop and recreate aggs. Again you can
maybe just do it for ST_Union since I think ST_ASMVT has some aggs and
those changes you might want to do.
> I have to lookup the sys catalogs but I think there is a way to directly
update the sys catalogs to set the parallel safe bit on by directly
updating the catalogs.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3821#comment:25>
