[postgis-tickets] [PostGIS] #3821: Don't drop st_union when updating postgis extension to 2.4
trac at osgeo.org
Sat Sep 28 16:51:12 PDT 2019
Reporter: nextstopsun | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: 2.3.x
Resolution: fixed | Keywords:
Comment (by robe):
dmkaplan2000,
Sadly as mentioned about going from 2.4 to 2.5.2 DOES REQUIRE a DROP
AGGREGATE. You don't even want to edit this script as that would put your
system in an unstable state if you do not drop the aggregate.
What was discussed above was when we changed midstream in a development
cycle, marking ST_Union as parallel safe -- that change can be done with a
catalog update and even if you don't not a huge deal -- just means your
ST_Union couldn't use paralle constructs.
Unfortunately going from 2.4 -> 2.5 we changed the underlying helper
functions so not a trivial catalog update.
A PostgreSQL team member (Andrew aka (RhodiumToad) ), heard our pains and
blessed us with an ALTER AGGREGATE SQL construct in PostgreSQL 12 which we
can use for most cases. So if running PostgreSQL 12 or above we use
ALTER AGGREGATE to make changes. That doesn't come till 3.0 though.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3821#comment:26>
