[postgis-tickets] [PostGIS] #4474: bessie32 failing
trac at osgeo.org
Sat Sep 28 12:37:04 PDT 2019
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: Management 2.0
Component: buildbots | Version: 2.5.x
Resolution: | Keywords:
Comment (by robe):
Well this sucks. I built a new bessie32 from FreeBSD 12 image
https://download.freebsd.org/ftp/releases/VM-
IMAGES/12.0-RELEASE/i386/Latest/FreeBSD-12.0-RELEASE-i386.vmdk.xz(date DEC
2018)
(compared to upgrading the FreeBSD 11 install) and to my disappointment,
it ended in the same error after I was done installing everything.
What I don't understand is why everything works fine in PostGIS 2.5. As I
recall PostGIS 2.5 compiles and regresses fine (aside from the known
32-bit freebsd issues).
Only thing I can think of is maybe our reliance now on pkg-config or that
our special source for using new Proj 6 features is bringing something
else in that PostgreSQL doesn't like.
Note that in 2.5 - gdal is the same, proj is the same, geos is the same,
and PostgreSQL is the same
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4474#comment:10>
