[postgis-tickets] [PostGIS] #4474: bessie32 failing
trac at osgeo.org
Sat Sep 28 12:38:43 PDT 2019
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: Management 2.0
Component: buildbots | Version: 2.5.x
Resolution: | Keywords:
Comment (by robe):
If the bessie 64-bit experiment works better using portsnap, I'll use that
instead of using the binary install approach. Just that portsnap is so
painfully slow since it compiles all the gdal dependencies and I was
stupid enought to check -- yah I want netcdf and popler and curl. Maybe I
shouldn't have gone so shopping cart crazy.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4474#comment:11>
