[postgis-tickets] [PostGIS] #4474: bessie32 failing
trac at osgeo.org
Sat Sep 28 15:32:32 PDT 2019
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: Management 2.0
Component: buildbots | Version: 2.5.x
Resolution: | Keywords:
Comment (by robe):
Getting back to your idea about the 2 different compilers being
incompatible, I noticed this and wagyu is new in 3.0, which would explain
why it might not be an issue in 2.5
-------------- Compiler Info -------------
18:17:03 C compiler: gcc -std=gnu99 -g -O2 -fno-math-errno
-fno-signed-zeros
18:17:03 C++ compiler (Wagyu): gcc8 -std=c++11 -x c++
18:17:03 CPPFLAGS: -I/usr/local/include
-I/usr/local/include -I/usr/local/include -I/usr/local/include/libxml2
-I/usr/include -I/usr/local/include -I/usr/local/include/json-c
18:17:03 SQL preprocessor: /usr/bin/cpp -traditional-cpp -w -P
18:17:03
On FreeBSD 12 64 bit which doesn't have the issue, it has this:
10:14:07 C compiler: cc -std=gnu99 -g -O2 -fno-math-errno
-fno-signed-zeros
10:14:07 C++ compiler (Wagyu): cc -std=c++11 -x c++
so looks like the 32-bit is using a different compiler for wagyu for some
reason.
At anyrate I'm testing now turning off wagyu to see if it solves the
issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4474#comment:12>
