[postgis-tickets] [PostGIS] #4500: ReprojectPts regression on FreeBSD 12 / Proj 6.1.0
PostGIS trac at osgeo.org
Sat Sep 28 15:54:23 PDT 2019
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 Some added info -- now that I have bessie32 at least regressing again, she
 has the same issue with proj.
 If I go thru the whole ports exercise again I'm going to maybe try the
 FORCE install approach instead of opting to remove GDAL/libgeotiff and
 install that from ports.  Installing GDAL via ports is extremely painful
 -- all these prompts I got to answer for all the dependency libraries as
 it downloads and compiles each of those. It finally got to the step of
 compiling GDAL.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4500#comment:10>
