[postgis-tickets] [PostGIS] #4500: ReprojectPts regression on FreeBSD 12 / Proj 6.1.0 and Proj 6.1.1 (was: ReprojectPts regression on FreeBSD 12 / Proj 6.1.0)
PostGIS trac at osgeo.org
Sat Sep 28 16:20:20 PDT 2019
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 Bah all that work and still the same issue:
 PostgreSQL 11.4 on amd64-portbld-freebsd12.0, compiled by FreeBSD clang
 version 6.0.1 (tags/RELEASE_601/final 335540) (based on LLVM 6.0.1),
 64-bit
   Postgis 3.0.0alpha5dev - r17827 - 2019-09-28 19:13:43
   scripts 3.0.0alpha5dev r17827
   GEOS: 3.7.2-CAPI-1.11.2 b55d2125
   PROJ: 6.1.1
 Running tests
  ../loader/Point .............. ok
  ../loader/PointM .............. ok
  ../loader/PointZ .............. ok
  ../loader/MultiPoint .............. ok
  ../loader/MultiPointM .............. ok
  ../loader/MultiPointZ .............. ok
  ../loader/Arc .............. ok
  ../loader/ArcM .............. ok
  ../loader/ArcZ .............. ok
  ../loader/Polygon .............. ok
  ../loader/PolygonM .............. ok
  ../loader/PolygonZ .............. ok
  ../loader/TSTPolygon ......... ok
  ../loader/TSIPolygon ......... ok
  ../loader/TSTIPolygon ......... ok
  ../loader/PointWithSchema ..... ok
  ../loader/NoTransPoint ......... ok
  ../loader/NotReallyMultiPoint ......... ok
  ../loader/MultiToSinglePoint ......... ok
  ../loader/ReprojectPts ..... failed (wkt testdiff expected obtained:
 /home/jenkins/tmp/pgis_reg_/test_20_diff)
 --- ../loader/ReprojectPts-w.select.expected    2019-09-28
 10:42:46.255801000 +0000
 +++ /home/jenkins/tmp/pgis_reg_/test_20_out     2019-09-28
 19:16:48.016016000 +0000
 @@ -1,66 +1,66 @@
 -SRID=4326;POINT(-74.17782492 41.08263361)
 -SRID=4326;POINT(-74.44881286 40.50133744)
 +SRID=4326;POINT(-74.17782443 41.08263361)
 +SRID=4326;POINT(-74.4488128 40.50133699)
  SRID=4326;POINT(-74.00376358 40.28149688)
  SRID=4326;POINT(-75.12863742 39.7797389)
 -SRID=4326;POINT(-74.57629014 40.85597595)
 -SRID=4326;POINT(-74.47160401 40.52369066)
 +SRID=4326;POINT(-74.57628962 40.85597621)
 +SRID=4326;POINT(-74.47160381 40.52369026)
  SRID=4326;POINT(-75.46891683 39.69688334)
  SRID=4326;POINT(-75.11458618 39.70739231)
  SRID=4326;POINT(-74.22643701 40.09726563)
 -SRID=4326;POINT(-74.26766926 40.83522615)
 -SRID=4326;POINT(-74.42152037 40.76232181)
 -SRID=4326;POINT(-74.18666598 40.89980341)
 -SRID=4326;POINT(-74.20201874 40.94448827)
 -SRID=4326;POINT(-74.31866663 40.6680465)
 -SRID=4326;POINT(-74.83205963 40.84912898)
 +SRID=4326;POINT(-74.26766872 40.8352264)
 +SRID=4326;POINT(-74.42151978 40.76232209)
 +SRID=4326;POINT(-74.1866655 40.89980354)
 +SRID=4326;POINT(-74.20201825 40.94448845)
 +SRID=4326;POINT(-74.31866643 40.66804657)
 +SRID=4326;POINT(-74.83205905 40.84912911)
  SRID=4326;POINT(-74.64402101 39.96633708)
  SRID=4326;POINT(-74.22194028 40.09559148)
 -SRID=4326;POINT(-74.60375255 40.75504208)
 -SRID=4326;POINT(-74.09376018 40.86569336)
 -SRID=4326;POINT(-74.4430374 40.77797967)
 +SRID=4326;POINT(-74.60375193 40.75504234)
 +SRID=4326;POINT(-74.09375981 40.86569326)
 +SRID=4326;POINT(-74.44303683 40.77797995)
  SRID=4326;POINT(-74.76841703 40.22038455)
 -SRID=4326;POINT(-74.19078182 40.73914574)
 -SRID=4326;POINT(-74.19628444 40.79591416)
 -SRID=4326;POINT(-74.19130306 40.74330253)
 -SRID=4326;POINT(-74.17636308 40.73783123)
 +SRID=4326;POINT(-74.19078139 40.73914578)
 +SRID=4326;POINT(-74.19628396 40.79591425)
 +SRID=4326;POINT(-74.19130262 40.74330258)
 +SRID=4326;POINT(-74.17636268 40.73783123)
  SRID=4326;POINT(-74.53148731 39.49029456)
 -SRID=4326;POINT(-74.16618054 40.73634864)
 -SRID=4326;POINT(-74.35732607 40.80076793)
 -SRID=4326;POINT(-74.17573811 40.73901418)
 +SRID=4326;POINT(-74.16618015 40.7363486)
 +SRID=4326;POINT(-74.35732552 40.80076819)
 +SRID=4326;POINT(-74.1757377 40.73901418)
  SRID=4326;POINT(-74.66491581 40.34572735)
 -SRID=4326;POINT(-74.36625323 40.51061374)
 -SRID=4326;POINT(-74.17631876 40.74329159)
 -SRID=4326;POINT(-74.4544664 40.52427239)
 -SRID=4326;POINT(-74.02836656 40.89756584)
 +SRID=4326;POINT(-74.36625351 40.51061338)
 +SRID=4326;POINT(-74.17631833 40.74329159)
 +SRID=4326;POINT(-74.45446627 40.524272)
 +SRID=4326;POINT(-74.02836625 40.89756567)
  SRID=4326;POINT(-75.00833975 39.82895026)
  SRID=4326;POINT(-74.13132221 40.33161528)
  SRID=4326;POINT(-74.67999522 39.46203859)
 -SRID=4326;POINT(-74.08904806 40.9515804)
 +SRID=4326;POINT(-74.08904769 40.95158042)
  SRID=4326;POINT(-75.12091068 39.94826917)
 -SRID=4326;POINT(-74.08628025 40.70929009)
 +SRID=4326;POINT(-74.08628002 40.70928983)
  SRID=4326;POINT(-74.73270242 40.27825159)
 Did we change this test between 2.5 and 3.0?  I know I added
 ReprojectPtsD, but I don't recall touching the original tests.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4500#comment:11>
