[postgis-tickets] [PostGIS] #4474: bessie32 FreeBSD12 32-bit wagyu compile causes undefined symbol error
PostGIS trac at osgeo.org
Mon Sep 30 02:40:50 PDT 2019
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  Management 2.0
 Component:  buildbots  |    Version:  2.5.x
Resolution:             |   Keywords:
Comment (by Algunenano):
 > so looks like the 32-bit is using a different compiler for wagyu for
 some reason.
 Wagyu is built with the same compiler as the extension, that is `pg_config
 --cc`, so you've probably built PG with gcc8 and the rest of the
 dependencies with gcc.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4474#comment:16>
