[postgis-tickets] [PostGIS] #4474: bessie32 FreeBSD12 32-bit wagyu compile causes undefined symbol error
trac at osgeo.org
Mon Sep 30 08:27:20 PDT 2019
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: Management 2.0
Component: buildbots | Version: 2.5.x
Resolution: | Keywords:
Comment (by robe):
I didn't build PG. PG I got from
pkg install postgresql
I always thought the rest of postgis would use the same. I wonder if this
is a similar issue to winnie. To get around winnie's issue, I just did
LDFLAGS="-Wl,--enable-auto-import...
winnie has below though I assumed gcc = x86_64-w64-mingw32-gcc are just
aliases for one another. Why it chooses one name in one can and another
in another seems a bit odd though
------------- Compiler Info -------------
C compiler: x86_64-w64-mingw32-gcc -std=gnu99 -g -O2 -fno-
math-errno -fno-signed-zeros
C++ compiler (Wagyu): gcc -std=c++11 -x c++
CPPFLAGS: -IE:/jenkins/geos/rel-3.8w64gcc81/include
-I/projects/proj/rel-5.2.0w64gcc81/include
-IE:/jenkins/protobuf/rel-3.2.0w64gcc81/include -I/projects/libxml/rel-
libxml2-2.9.9w64gcc81/include/libxml2 -I/projects/CGAL/rel-
sfcgal-1.3.2w64gcc81/include
-IE:/jenkins/json-c/rel-0.12w64gcc81/include/json-c
-IE:/jenkins/pcre/rel-8.33w64gcc81/include
SQL preprocessor: /mingw64/bin/cpp -traditional-cpp -w -P
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4474#comment:17>
