[postgis-tickets] [PostGIS] #4516: Upgrade from 2.4 to 3.0
trac at osgeo.org
Mon Sep 30 07:47:06 PDT 2019
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: 2.5.x
Keywords: |
This person was upgrading using scripts instead of extensions so not sure
if its an issue as well upgrading using extensions
Excerpt from https://lists.osgeo.org/pipermail/postgis-
devel/2019-September/028098.html
Yes, we use legacy functions; we haven't switched to using 'CREATE
EXTENSION'
yet (I don't think we can install legacy stuff that way, so it seems not
useful
to install postgis one way and its legacy functions another way).
It occured to me that possible I should've rerun "postgis_upgrade.sql"
with the
latest 2.4 RPM before upgrading to 3.0. But I think we *have* the latest
2.4
RPM (from PGDG), and I'd have to think about whether the pacakge would've
ever
been updated since it was first installed. So I think that probably isn't
a
solution, for us at least.
I pulled the errors out of logs, sorry for not saving the the first time.
-[ RECORD 2
log_time | 2019-09-27 10:10:08.243-06
left | cannot change name of input parameter "geom1"
detail |
query | CREATE OR REPLACE FUNCTION _ST_LineCrossingDirection(line1
geometry, line2 geometry) +
| RETURNS integer
| AS '$libdir/postgis-3', 'ST_LineCrossingDirection'
| LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
| COST 10;
-[ RECORD 3
log_time | 2019-09-27 10:10:27.438-06
left | cannot change name of input parameter "geometrya"
detail |
query | CREATE OR REPLACE FUNCTION _ST_OrderingEquals(geom1 geometry,
geom2 geometry) +
| RETURNS boolean
| AS '$libdir/postgis-3', 'LWGEOM_same'
| COST 10;
[... eliding my own errors here...]
-[ RECORD 5
log_time | 2019-09-27 10:10:42.418-06
detail |
query | CREATE OR REPLACE FUNCTION ST_LineCrossingDirection(line1
| RETURNS integer AS
| $$ SELECT CASE WHEN NOT $1 OPERATOR(&&) $2 THEN 0 ELSE
_ST_LineCrossingDirection($1,$2) END $$+
| LANGUAGE 'sql' IMMUTABLE PARALLEL SAFE;
-[ RECORD 6
log_time | 2019-09-27 10:10:58.199-06
left | cannot drop function st_combine_bbox(box3d,geometry) because
other objects depend on it
detail | function st_extent3d(geometry) depends on function
st_combine_bbox(box3d,geometry) +
| function extent(geometry) depends on function
query | DROP FUNCTION IF EXISTS st_combine_bbox(box3d, geometry);
-[ RECORD 7
log_time | 2019-09-27 10:11:14.194-06
query | DROP FUNCTION st_combine_bbox(box3d,geometry);
-[ RECORD 9
log_time | 2019-09-27 10:11:34.634-06
detail | function extent(geometry) depends on function
-[ RECORD 10
log_time | 2019-09-27 10:12:34.127-06
left | function "extent3d" already exists with same argument types
detail |
query | CREATE AGGREGATE Extent3d(
| sfunc = combine_bbox,
| basetype = geometry,
| stype = box3d
-[ RECORD 11
left | function "memcollect" already exists with same argument types
detail |
query | CREATE AGGREGATE memcollect(
| sfunc = ST_collect,
| stype = geometry
-[ RECORD 12
log_time | 2019-09-27 10:13:36.998-06
left | function "extent" already exists with same argument types
detail |
query | CREATE AGGREGATE Extent(
| sfunc = ST_CombineBbox,
| finalfunc = box2d,
| stype = box3d
-[ RECORD 13
log_time | 2019-09-27 10:13:37.042-06
left | function "makeline" already exists with same argument types
detail |
query | CREATE AGGREGATE makeline (
| BASETYPE = geometry,
| SFUNC = pgis_geometry_accum_transfn,
| STYPE = internal,
| FINALFUNC = pgis_geometry_makeline_finalfn
-[ RECORD 14
log_time | 2019-09-27 10:13:37.132-06
detail |
| stype = box3d
-[ RECORD 15
detail |
| sfunc = ST_collect,
| stype = geometry
-[ RECORD 16
log_time | 2019-09-27 10:13:37.136-06
left | function "st_extent3d" already exists with same argument types
detail |
query | CREATE AGGREGATE ST_Extent3D(
| stype = box3d
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4516>
