[postgis-tickets] [PostGIS] #4474: bessie32 FreeBSD12 32-bit wagyu compile causes undefined symbol error
PostGIS trac at osgeo.org
Mon Sep 30 11:55:42 PDT 2019
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  closed
  Priority:  blocker    |  Milestone:  Management 2.0
 Component:  buildbots  |    Version:  2.5.x
Resolution:  fixed      |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17838" 17838]:
 #!CommitTicketReference repository="" revision="17838"
 Add CXX and CXXFLAGS from pg_config seems to fix wagyu load issue
 Closes #4474
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4474#comment:21>
