[postgis-tickets] r17838 - Add CXX and CXXFLAGS from pg_config seems to fix wagyu load issue
Regina Obe
lr at pcorp.us
Mon Sep 30 11:55:41 PDT 2019
Author: robe
Date: 2019-09-30 11:55:41 -0700 (Mon, 30 Sep 2019)
New Revision: 17838
trunk/ci/bessie32/postgis_regress.sh
Closes #4474
Modified: trunk/ci/bessie32/postgis_regress.sh
--- trunk/ci/bessie32/postgis_regress.sh 2019-09-30 16:38:37 UTC (rev 17837)
+++ trunk/ci/bessie32/postgis_regress.sh 2019-09-30 18:55:41 UTC (rev 17838)
@@ -1,7 +1,9 @@
#export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
sh autogen.sh
CC=gcc8 \
-CFLAGS="-Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-trunc" \
+CXX=g++8 \
+CXXFLAGS="-O2 -pipe -fstack-protector-strong -Wl,-rpath=/usr/local/lib/gcc8 -nostdinc++ -isystem /usr/include/c++/v1 -Wl,-rpath=/usr/local/lib/gcc8" \
+CFLAGS="-Wall -Wmissing-prototypes -Wpointer-arith -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-trunc" \
./configure --with-libiconv=/usr/local --without-interrupt-tests
make clean
make
