[postgis-tickets] r17839 - Avoid datum/grid shifts in reproject test, to lower
Paul Ramsey
pramsey at cleverelephant.ca
Mon Sep 30 12:49:09 PDT 2019
Author: pramsey
Date: 2019-09-30 12:49:09 -0700 (Mon, 30 Sep 2019)
New Revision: 17839
trunk/regress/loader/ReprojectPts-w.select.expected
trunk/regress/loader/ReprojectPts.opts
trunk/regress/loader/ReprojectPts.select.expected
trunk/regress/loader/ReprojectPtsD.opts
trunk/regress/loader/ReprojectPtsD.select.expected
trunk/regress/loader/ReprojectPtsGeog-w.select.expected
trunk/regress/loader/ReprojectPtsGeog.opts
trunk/regress/loader/ReprojectPtsGeog.select.expected
trunk/regress/loader/ReprojectPtsGeogD-w.select.expected
trunk/regress/loader/ReprojectPtsGeogD.opts
trunk/regress/loader/ReprojectPtsGeogD.select.expected
sensitivity to variance in proj installations wrt
whether or not grid shift files are installed.
References #4500
Modified: trunk/regress/loader/ReprojectPts-w.select.expected
--- trunk/regress/loader/ReprojectPts-w.select.expected 2019-09-30 18:55:41 UTC (rev 17838)
+++ trunk/regress/loader/ReprojectPts-w.select.expected 2019-09-30 19:49:09 UTC (rev 17839)
@@ -1,66 +1,66 @@
-SRID=4326;POINT(-74.17782492 41.08263361)
-SRID=4326;POINT(-74.44881286 40.50133744)
-SRID=4326;POINT(-74.00376358 40.28149688)
-SRID=4326;POINT(-75.12863742 39.7797389)
-SRID=4326;POINT(-74.57629014 40.85597595)
-SRID=4326;POINT(-74.47160401 40.52369066)
-SRID=4326;POINT(-75.46891683 39.69688334)
-SRID=4326;POINT(-75.11458618 39.70739231)
-SRID=4326;POINT(-74.22643701 40.09726563)
-SRID=4326;POINT(-74.26766926 40.83522615)
-SRID=4326;POINT(-74.42152037 40.76232181)
-SRID=4326;POINT(-74.18666598 40.89980341)
-SRID=4326;POINT(-74.20201874 40.94448827)
-SRID=4326;POINT(-74.31866663 40.6680465)
-SRID=4326;POINT(-74.83205963 40.84912898)
-SRID=4326;POINT(-74.64402101 39.96633708)
-SRID=4326;POINT(-74.22194028 40.09559148)
-SRID=4326;POINT(-74.60375255 40.75504208)
-SRID=4326;POINT(-74.09376018 40.86569336)
-SRID=4326;POINT(-74.4430374 40.77797967)
-SRID=4326;POINT(-74.76841703 40.22038455)
-SRID=4326;POINT(-74.19078182 40.73914574)
-SRID=4326;POINT(-74.19628444 40.79591416)
-SRID=4326;POINT(-74.19130306 40.74330253)
-SRID=4326;POINT(-74.17636308 40.73783123)
-SRID=4326;POINT(-74.53148731 39.49029456)
-SRID=4326;POINT(-74.16618054 40.73634864)
-SRID=4326;POINT(-74.35732607 40.80076793)
-SRID=4326;POINT(-74.17573811 40.73901418)
-SRID=4326;POINT(-74.66491581 40.34572735)
-SRID=4326;POINT(-74.36625323 40.51061374)
-SRID=4326;POINT(-74.17631876 40.74329159)
-SRID=4326;POINT(-74.4544664 40.52427239)
-SRID=4326;POINT(-74.02836656 40.89756584)
-SRID=4326;POINT(-75.00833975 39.82895026)
-SRID=4326;POINT(-74.13132221 40.33161528)
-SRID=4326;POINT(-74.67999522 39.46203859)
-SRID=4326;POINT(-74.08904806 40.9515804)
-SRID=4326;POINT(-75.12091068 39.94826917)
-SRID=4326;POINT(-74.08628025 40.70929009)
-SRID=4326;POINT(-74.73270242 40.27825159)
-SRID=4326;POINT(-74.16625303 40.01000431)
-SRID=4326;POINT(-75.01837982 40.74472398)
-SRID=4326;POINT(-74.65920653 40.34951097)
-SRID=4326;POINT(-74.24751143 40.74434122)
-SRID=4326;POINT(-74.65122484 40.25151634)
-SRID=4326;POINT(-74.43880205 40.4659008)
-SRID=4326;POINT(-74.2355417 40.68231466)
-SRID=4326;POINT(-74.49892935 40.80763833)
-SRID=4326;POINT(-74.0625762 40.73086062)
-SRID=4326;POINT(-75.03600164 39.78659251)
-SRID=4326;POINT(-75.05591643 39.44084942)
-SRID=4326;POINT(-74.39804333 40.50086907)
-SRID=4326;POINT(-74.07131567 40.72720191)
-SRID=4326;POINT(-74.19117919 40.74196293)
-SRID=4326;POINT(-74.02494262 40.74676479)
-SRID=4326;POINT(-74.68894668 40.6094749)
-SRID=4326;POINT(-74.44600226 40.49825884)
-SRID=4326;POINT(-74.19898991 40.85779571)
-SRID=4326;POINT(-74.7828046 40.27094999)
-SRID=4326;POINT(-74.25017536 40.217432)
-SRID=4326;POINT(-74.16960551 40.91844326)
-SRID=4326;POINT(-74.75788852 41.06754763)
-SRID=4326;POINT(-74.03363729 40.72689071)
-SRID=4326;POINT(-74.5760699 40.53743164)
-SRID=4326;POINT(-74.43925667 40.77359187)
+SRID=4269;POINT(-74.17782492 41.08263361)
+SRID=4269;POINT(-74.44881286 40.50133744)
+SRID=4269;POINT(-74.00376358 40.28149688)
+SRID=4269;POINT(-75.12863742 39.7797389)
+SRID=4269;POINT(-74.57629014 40.85597595)
+SRID=4269;POINT(-74.47160401 40.52369066)
+SRID=4269;POINT(-75.46891683 39.69688334)
+SRID=4269;POINT(-75.11458618 39.70739231)
+SRID=4269;POINT(-74.22643701 40.09726563)
+SRID=4269;POINT(-74.26766926 40.83522615)
+SRID=4269;POINT(-74.42152037 40.76232181)
+SRID=4269;POINT(-74.18666598 40.89980341)
+SRID=4269;POINT(-74.20201874 40.94448827)
+SRID=4269;POINT(-74.31866663 40.6680465)
+SRID=4269;POINT(-74.83205963 40.84912898)
+SRID=4269;POINT(-74.64402101 39.96633708)
+SRID=4269;POINT(-74.22194028 40.09559148)
+SRID=4269;POINT(-74.60375255 40.75504208)
+SRID=4269;POINT(-74.09376018 40.86569336)
+SRID=4269;POINT(-74.4430374 40.77797967)
+SRID=4269;POINT(-74.76841703 40.22038455)
+SRID=4269;POINT(-74.19078182 40.73914574)
+SRID=4269;POINT(-74.19628444 40.79591416)
+SRID=4269;POINT(-74.19130306 40.74330253)
+SRID=4269;POINT(-74.17636308 40.73783123)
+SRID=4269;POINT(-74.53148731 39.49029456)
+SRID=4269;POINT(-74.16618054 40.73634864)
+SRID=4269;POINT(-74.35732607 40.80076793)
+SRID=4269;POINT(-74.17573811 40.73901418)
+SRID=4269;POINT(-74.66491581 40.34572735)
+SRID=4269;POINT(-74.36625323 40.51061374)
+SRID=4269;POINT(-74.17631876 40.74329159)
+SRID=4269;POINT(-74.4544664 40.52427239)
+SRID=4269;POINT(-74.02836656 40.89756584)
+SRID=4269;POINT(-75.00833975 39.82895026)
+SRID=4269;POINT(-74.13132221 40.33161528)
+SRID=4269;POINT(-74.67999522 39.46203859)
+SRID=4269;POINT(-74.08904806 40.9515804)
+SRID=4269;POINT(-75.12091068 39.94826917)
+SRID=4269;POINT(-74.08628025 40.70929009)
+SRID=4269;POINT(-74.73270242 40.27825159)
+SRID=4269;POINT(-74.16625303 40.01000431)
+SRID=4269;POINT(-75.01837982 40.74472398)
+SRID=4269;POINT(-74.65920653 40.34951097)
+SRID=4269;POINT(-74.24751143 40.74434122)
+SRID=4269;POINT(-74.65122484 40.25151634)
+SRID=4269;POINT(-74.43880205 40.4659008)
+SRID=4269;POINT(-74.2355417 40.68231466)
+SRID=4269;POINT(-74.49892935 40.80763833)
+SRID=4269;POINT(-74.0625762 40.73086062)
+SRID=4269;POINT(-75.03600164 39.78659251)
+SRID=4269;POINT(-75.05591643 39.44084942)
+SRID=4269;POINT(-74.39804333 40.50086907)
+SRID=4269;POINT(-74.07131567 40.72720191)
+SRID=4269;POINT(-74.19117919 40.74196293)
+SRID=4269;POINT(-74.02494262 40.74676479)
+SRID=4269;POINT(-74.68894668 40.6094749)
+SRID=4269;POINT(-74.44600226 40.49825884)
+SRID=4269;POINT(-74.19898991 40.85779571)
+SRID=4269;POINT(-74.7828046 40.27094999)
+SRID=4269;POINT(-74.25017536 40.217432)
+SRID=4269;POINT(-74.16960551 40.91844326)
+SRID=4269;POINT(-74.75788852 41.06754763)
+SRID=4269;POINT(-74.03363729 40.72689071)
+SRID=4269;POINT(-74.5760699 40.53743164)
+SRID=4269;POINT(-74.43925667 40.77359187)
Modified: trunk/regress/loader/ReprojectPts.opts
--- trunk/regress/loader/ReprojectPts.opts 2019-09-30 18:55:41 UTC (rev 17838)
+++ trunk/regress/loader/ReprojectPts.opts 2019-09-30 19:49:09 UTC (rev 17839)
@@ -1,3 +1,3 @@
# This happens to be a multipoint shapefile that has only single points, so use -S.
# It is in NJ State Plane NAD83, so reproject to 4326.
--S -s 2260:4326
+-S -s 2260:4269
Modified: trunk/regress/loader/ReprojectPts.select.expected
--- trunk/regress/loader/ReprojectPts.select.expected 2019-09-30 18:55:41 UTC (rev 17838)
+++ trunk/regress/loader/ReprojectPts.select.expected 2019-09-30 19:49:09 UTC (rev 17839)
@@ -1,66 +1,66 @@
Modified: trunk/regress/loader/ReprojectPtsD.opts
--- trunk/regress/loader/ReprojectPtsD.opts 2019-09-30 18:55:41 UTC (rev 17838)
+++ trunk/regress/loader/ReprojectPtsD.opts 2019-09-30 19:49:09 UTC (rev 17839)
@@ -1,3 +1,3 @@
# It is in NJ State Plane NAD83, so reproject to 4326 using copy mode
--D -S -s 2260:4326
+-D -S -s 2260:4269
Modified: trunk/regress/loader/ReprojectPtsD.select.expected
--- trunk/regress/loader/ReprojectPtsD.select.expected 2019-09-30 18:55:41 UTC (rev 17838)
+++ trunk/regress/loader/ReprojectPtsD.select.expected 2019-09-30 19:49:09 UTC (rev 17839)
@@ -1,66 +1,66 @@
Modified: trunk/regress/loader/ReprojectPtsGeog-w.select.expected
--- trunk/regress/loader/ReprojectPtsGeog-w.select.expected 2019-09-30 18:55:41 UTC (rev 17838)
+++ trunk/regress/loader/ReprojectPtsGeog-w.select.expected 2019-09-30 19:49:09 UTC (rev 17839)
@@ -1,66 +1,66 @@
Modified: trunk/regress/loader/ReprojectPtsGeog.opts
--- trunk/regress/loader/ReprojectPtsGeog.opts 2019-09-30 18:55:41 UTC (rev 17838)
+++ trunk/regress/loader/ReprojectPtsGeog.opts 2019-09-30 19:49:09 UTC (rev 17839)
@@ -1,3 +1,3 @@
# It is in NJ State Plane NAD83, using the -G flag will reproject to 4326.
--S -s 2260:4326 -G
+-S -s 2260:4269 -G
Modified: trunk/regress/loader/ReprojectPtsGeog.select.expected
--- trunk/regress/loader/ReprojectPtsGeog.select.expected 2019-09-30 18:55:41 UTC (rev 17838)
+++ trunk/regress/loader/ReprojectPtsGeog.select.expected 2019-09-30 19:49:09 UTC (rev 17839)
@@ -1,66 +1,66 @@
Modified: trunk/regress/loader/ReprojectPtsGeogD-w.select.expected
--- trunk/regress/loader/ReprojectPtsGeogD-w.select.expected 2019-09-30 18:55:41 UTC (rev 17838)
+++ trunk/regress/loader/ReprojectPtsGeogD-w.select.expected 2019-09-30 19:49:09 UTC (rev 17839)
@@ -1,66 +1,66 @@
Modified: trunk/regress/loader/ReprojectPtsGeogD.opts
--- trunk/regress/loader/ReprojectPtsGeogD.opts 2019-09-30 18:55:41 UTC (rev 17838)
+++ trunk/regress/loader/ReprojectPtsGeogD.opts 2019-09-30 19:49:09 UTC (rev 17839)
@@ -1,3 +1,3 @@
# It is in NJ State Plane NAD83, using the -D copy mode, -s reproject to 4326, -G flag cast a geography.
--D -S -s 2260:4326 -G
+-D -S -s 2260:4269 -G
Modified: trunk/regress/loader/ReprojectPtsGeogD.select.expected
--- trunk/regress/loader/ReprojectPtsGeogD.select.expected 2019-09-30 18:55:41 UTC (rev 17838)
+++ trunk/regress/loader/ReprojectPtsGeogD.select.expected 2019-09-30 19:49:09 UTC (rev 17839)
@@ -1,66 +1,66 @@
