[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-49-gd92c6b7
git at osgeo.org
git at osgeo.org
Wed Apr 1 01:02:53 PDT 2020
the project "PostGIS".
via d92c6b7cf4b3c8078b6ffcbc59a91462db57f92a (commit)
from 697a9bd99cb3ebce7ba5bcdb685f35dc18b9a591 (commit)
revisions in full, below.
commit d92c6b7cf4b3c8078b6ffcbc59a91462db57f92a
Author: Raúl Marín <git at rmr.ninja>
Date: Tue Mar 31 15:48:09 2020 +0200
Support casting a geojson text to geometry
Closes https://github.com/postgis/postgis/pull/551
Closes #4656
diff --git a/NEWS b/NEWS
index f771baf..e655f2e 100644
--- a/NEWS
+++ b/NEWS
@@ -7,13 +7,13 @@ Only tickets not included in 3.1.0alpha1
* New features *
+ - #4656, Cast a geojson_text::geometry for implicit GeoJSON ingestion (Raúl Marín)
* Enhancements *
- - #4651: ST_Simplify: Don't copy if nothing is removed
+ - #4651: ST_Simplify: Don't copy if nothing is removed (Raúl Marín)
* Bug fixes *
- - #4652, Fix several memory related bugs in ST_GeomFromGML
+ - #4652, Fix several memory related bugs in ST_GeomFromGML (Raúl Marín)
PostGIS 3.1.0alpha1
2020/02/01
diff --git a/postgis/lwgeom_inout.c b/postgis/lwgeom_inout.c
index be4b2ee..3a31a2d 100644
--- a/postgis/lwgeom_inout.c
+++ b/postgis/lwgeom_inout.c
@@ -45,6 +45,7 @@
#include "funcapi.h"
#include "liblwgeom.h"
+#include "lwgeom_export.h"
#include "lwgeom_pg.h"
#include "geography.h" /* for lwgeom_valid_typmod */
#include "lwgeom_transform.h"
@@ -70,7 +71,6 @@ Datum TWKBFromLWGEOM(PG_FUNCTION_ARGS);
Datum TWKBFromLWGEOMArray(PG_FUNCTION_ARGS);
Datum LWGEOMFromTWKB(PG_FUNCTION_ARGS);
* LWGEOM_in(cstring)
* format is '[SRID=#;]wkt|wkb'
@@ -78,6 +78,7 @@ Datum LWGEOMFromTWKB(PG_FUNCTION_ARGS);
* LWGEOM_in( 'POINT(0 0)') --> assumes SRID=SRID_UNKNOWN
* LWGEOM_in( 'SRID=99;0101000000000000000000F03F000000000000004')
* LWGEOM_in( '0101000000000000000000F03F000000000000004')
+ * LWGEOM_in( '{"type":"Point","coordinates":[1,1]}')
* returns a GSERIALIZED object
PG_FUNCTION_INFO_V1(LWGEOM_in);
@@ -140,6 +141,19 @@ Datum LWGEOM_in(PG_FUNCTION_ARGS)
ret = geometry_serialize(lwgeom);
lwgeom_free(lwgeom);
+ else if (str[0] == '{')
+ char *srs = NULL;
+ lwgeom = lwgeom_from_geojson(str, &srs);
+ if (srs)
+ srid = getSRIDbySRS(srs);
+ lwfree(srs);
+ lwgeom_set_srid(lwgeom, srid);
+ ret = geometry_serialize(lwgeom);
+ lwgeom_free(lwgeom);
/* WKT then. */
else
diff --git a/regress/core/in_geojson.sql b/regress/core/in_geojson.sql
index df6b7d6..cc4a34c 100644
--- a/regress/core/in_geojson.sql
+++ b/regress/core/in_geojson.sql
@@ -55,3 +55,7 @@ SELECT '#4470.a', ST_AsText(ST_GeomFromGeoJSON('{"type":"Polygon","coordinates":
SELECT '#4470.b', ST_AsText(ST_GeomFromGeoJSON('{"type":"Polygon","coordinates":[[],[0,0]]}'));
SELECT '#4470.c', ST_AsText(ST_GeomFromGeoJSON('{"type":"MultiPolygon","coordinates":[[[[0,0]],[]]]}'));
SELECT '#4470.d', ST_AsText(ST_GeomFromGeoJSON('{"type":"MultiPolygon","coordinates":[[[],[0,0]]]}'));
+-- ::geometry cast
+SELECT 'cast1', ST_AsEWKT('{"type":"Point","coordinates":[1,1]}'::geometry);
+SELECT 'cast2', ST_AsEWKT(st_asgeojson('SRID=3005;MULTIPOINT(1 1, 1 1)'::geometry)::geometry);
diff --git a/regress/core/in_geojson_expected b/regress/core/in_geojson_expected
index 0a0e7de..e3c4eec 100644
--- a/regress/core/in_geojson_expected
+++ b/regress/core/in_geojson_expected
@@ -36,3 +36,5 @@ ERROR: The 'coordinates' in GeoJSON are not sufficiently nested
#4470.b|POLYGON EMPTY
#4470.c|MULTIPOLYGON(((0 0)))
#4470.d|MULTIPOLYGON EMPTY
+cast1|POINT(1 1)
+cast2|SRID=3005;MULTIPOINT(1 1,1 1)
Summary of changes:
NEWS | 6 +++---
postgis/lwgeom_inout.c | 16 +++++++++++++++-
regress/core/in_geojson.sql | 4 ++++
regress/core/in_geojson_expected | 2 ++
4 files changed, 24 insertions(+), 4 deletions(-)
hooks/post-receive
